Question about Refrigerators
Kitchenaid superba refrigerator
Freezer and fridge are not cooling enough water everywhere. the fan on the bottom and the compressor seem to be working. HELP!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number? Do you see ice buildup on the freezer walls?
Posted on Dec 28, 2013
  • 1462 Answers
SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Our freezer and reridgerator temps are climbing and the front of the middle divider between the freezer and fridg is burning hot. What's the problem?
There is a condenser fan down at the compressor area that isn't running at enough rpms to properly cool compressor. You will need to clean the condenser coils and also install new condenser fan. The compressor is over heating and shutting down on internal overload. Replace this fan and you will be good to go. As an emergency aid you can pull unit from wall about 6 to 12 inches and place a fan in the front area out of your way letting it blow air thru the front over the compressor until you can get the fan. Hope this helps and good luck.
Feb 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
