Question about Electrical Supplies
We have a Kenmore garbage disposal # 175.605090
Fit this?
  • 3,368 Answers
So what about the garbage disposal??
Posted on Apr 29, 2014
4 Suggested Answers
  • 10865 Answers
SOURCE: Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
  • 5603 Answers
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Posted on Dec 30, 2009
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Need to replace kenmore 1/2 hp garbage disposer 60505. Would like install to be easy. What new model replaces the old 60505?
Hey,
Here's the info:
Kenmore 1/2 hp Garbage Disposal Model# 72433 Reg Price: $99.00
Savings: $19.12
$79.88
Source: http://www.kenmore.com/kenmore-1-2-hp-garbage-disposal/p-02206011000P
Dec 28, 2014 | Electrical Supplies
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
