Question about Copystar CS-2050 All-In-One Printer
Copystar 2550 having problem with fax copy finishing tray, i want to change the finishing to the copy tray and discontinue using the fax tray until i get enough money to have it repaired
    Problem Solver:
  • 9 Answers
It should have an external plug into the back of the copier. Disconnect it and it should no longer recognize it.
Posted on Dec 29, 2013
Testimonial: "No external plug on back of machine, I thought a setting has to be changed to direct all copies to the bottom finishing tray, (their are two finishing trays-the top tray is where the faxes come out-*that is the area the paper stops and machine says jammed..the bottom tray is finishing for the copy machine"
  • 215 Answers
SOURCE: copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Posted on Mar 30, 2009
  • 215 Answers
SOURCE: Copystar cs-2550 drum replacement problems
ok. try this, take the rear cover off, theres quite a few screws. what i'm thinking has happened is you may have pushed the contact for the main corona wire out of place. this board is pretty flimsy. once you have back cover off, the board will be slightly to the right of center as u r looking at machine from rear. i can't recall EXACTLY what board looks like, but if you loosen your drum unit and have someone pull out drum a little and push back in, you will see what and where i am talking about. i'm a tech and had this bite me in the behind one time. will never forget it. hopefully, that will take care of it for you. let me know what you find.
good luck,
razors
  • 630 Answers
SOURCE: Copystar cs-c2520 i have a faded line down the
Either a problem with the document feeder or something on the glass. If it's faded it may just be a roller not pushing the paper onto the scanning area properly.
Posted on Jul 20, 2009
n25an
  • 622 Answers
SOURCE: Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Posted on Dec 24, 2009
n25an
  • 622 Answers
SOURCE: Copystar cs-2550 service code c6000
bad fuser... replace it...
Posted on Dec 26, 2009
Cc 2550 when making copies using document
You need to clean or change the charger unit, if you open front cover you will see green unit going inside the drum, you can take it out and clean or if it is too bad change it.
Good luck
Aug 21, 2013 | Copystar Cs2550 Copier
Ii want to set the password kyocera 2550
Push the System Menu/Counter Button
Using arrow keys find the Machine Default-press enter
Use the factory set PIN (should be 2500)-press enter
Arrow to PIN# change-press enter
Using key pad choose new number-press enter then press the reset button
Feb 22, 2013 | Copystar CS-2550 All-In-One Printer
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Jan 09, 2013 | Kyocera Copystar CS-5035 Copier
Cs-2550 sofware
goto usa.copystar.com and search in downloads...
Nov 20, 2009 | Copystar CS-2550 All-In-One Printer
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
good luck,
razors
Mar 26, 2009 | Copystar CS-2550 All-In-One Printer
I need to change the old company name to the new one
Here is a link to the users manual. You just need to change the registration information.
http://usa.copystar.com/americas/jsp/upload/resource/13716/0/FAX-SYS-L-ENOG.pdf
Mar 20, 2009 | Copystar CS-2550 All-In-One Printer
Set the eject tray
is there a job seperator on this machine (gray tray in middle of paper eject)? If so try this...Press */language key @ left of control panel...Scroll down to "Machine default", press enter key...enter code 2000 or 6482...scroll to ejector of fax (if equipped) or ejector of copy...select what tray ...scroll up to "end"...press enter...that should bounce you back to "Ready to copy" screen.
Jul 06, 2008 | Copystar CS-2030 Copier
Copystar CS-2050 All-In-One Printer Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
