Question about Ovens
Whirlpool oven door
I had to pull my oven out to paint behind it. When I did the oven dor came partially off . When I tried to replace it the whole door came off and now I canot get it back on. The hinges have springs which I have pried open and put dowels in to hold them open while I tried to reattach the door but it still would not go on and eventually the hinges clamp shut with enough force to take your finger off. I really don't want to pay a repair person to come and reattach the door and I don't want to get a new oven if I don't have to. I am very frustrated by this and have wasted hours trying to get my door back on-not to mention I can't cook. Please help!
  • 7 more comments
  • Anonymous Dec 07, 2007
    Manual talks about putting a pin through the hinge before removing. Did not do that and there is no "hole punched out" where the diagram says the pin should go. Cannot put oven door back on. No support from Customer Serice at Whirlpool. Myrna adams myrna40@bellsouth.net
  • muymajo99 Mar 01, 2008
    In removing my oven door, I cannot get it to go back in. It has sit on top of the burners for the last couple of days. Help!
  • sandie_d May 26, 2008
    Imanaged to get my oven door off the hinge on one side. My husband tried to get it back on and ended up pulling the door completely off, We can't get it back on and we can not affoed a pfoffessional to come out and put it back on for us. My husband is 65 years old and very un-helpful around the home. Please give me a simple way to fix it myself. I would call a neighbor, but he is very jealous and I can't see me calling a neighbor and him being so mean to them.
  • adamangie Jun 01, 2008
    my oven door came off on one side and I can not get it back on
  • Anonymous Jul 03, 2008
     Put a piece of wood to keep it open. Didn't find any pinholes. I did it one clamp after the other.
  • Anonymous Apr 17, 2009
    awsome - the force on the hinge actually bent a steel nail so be carefull
  • Anonymous May 25, 2009
    need to get door off so i can get a new 1 so what do i do?
  • polarman4
    polarman4 Feb 16, 2013
    awesome help!! spen and hour throwing screwdrivers and screaming and cussing,read this,and spent more time looking for nails than it took to put the door back on!! thank you so much!!
  • leeann stevens
    leeann stevens Jan 14, 2014
    THANK YOU!
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Posted on Apr 28, 2008
  • 2 more comments
  • kerseysangel Mar 13, 2011
    Thank you very much for your help. We struggled and gave up hope and was ready to call a repair man thinking we had messed up entirely until I googled the question and found your sight. I can't thank you enough for the solution as it saved us some gray hair and a service call.
  • joemcgovern1
    joemcgovern1 Oct 15, 2012
    Awesome, Thank you. Easy fix once I knew what to do! Before that, t was bad.
  • haplocom
    haplocom Feb 21, 2013
    Thank you! Thank you! Thank you! Like every one else, after an hour of struggling,we looked it up-pryed the "hinges" farther than we thought we could nd there were the holes! A few big nails fit right in and our oven is cooking again!.
  • leeann stevens
    THANK YOU!!
I had the EXACT same problem as cabinrn. But I also found the solution about 5 minutes ago!!!! (After about an hour of trying to get the door back on and almost losing my finger multiple times.)
After prying open the hinges one at at time, using a towel wrapped around them for extra grip, I put a screw in each of the holes that are meant for the mysterious pins. I figured they could withstand the strength of the spring. This time when I tried putting the door back on the springs went right into place. The key is making sure you have these little metal pieces ( I have no idea how to describe them, sorry.) They don't look like they do much, but they are the only thing that holds the hinge in place so that it doesn't snap closed again. Once I put those back in, I opened the oven door, the screws I used to hold open the springs fell out and the door was re-attached.
Posted on Feb 13, 2008
  • renael44 Jan 03, 2011
    I, like many others tried and tried to get the oven door back on to no avail. This idea of using small but thick screws kept the hinges open and the door went back into place with no problems. Thanks zgirl!!
For a Whirlpool Gold model GR673LXSQ go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209763001.pdf and look at the directions on page 28.
Posted on Nov 19, 2009
USE #3!!!!! After an hour of struggling and almost losing his finger...not to mention the new words I learned, my husband tried the nail idea in Solution #3 and two minutes later, our range door is back on! Wooohooo! He says I'm his hero for googling and finding the answer to our problem. Actually Warrenj (solution #3) is the hero! Thanks!
  • 4,889 Answers
The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed..Fixing is just the other way around...
Posted on Oct 18, 2007
Our oven did not have the "magic nail hole". So I removed the screws at the top of the door which holds the to layers of door together. Next I took Channel Lock pliers and pulled the springs up and out to release them (use caution it is springs after all). Then I easily put the hinge in the door. Then pull the spring back into place with the door 3/4 closed. Last put the two top screws and handle back together and finished.
Posted on Dec 31, 2009
Thank you. I had the same problem, one of the hinges clamped shut when I had taken the door off to clean. I managed to prise it back open with the claw of a hammer and pull the clamp forward to stop it shutting again.
Posted on Mar 16, 2009
Was moving stove and over door came off. 3 of us tried for 1 hour trying to get it back on. Thanks to Solution #3, I did it by myself in 2 minutes. Let's hear it for the internet. Woooooo!
Posted on Aug 14, 2010
    Problem Solver:
I have a Whirlpool range without the holes in the hinges. I found the manual, and was told to take the door off (KEEP YOUR HANDS AWAY FROM THE HINGES, THEY WILL BITE!!!), put the top of the door in first,then put the hinges and apply sllight pressure to each side of the door as you pull up on the door, keeping it high and tight, after a couple of tries my wife got it to drop in place. Hope this helps someone!
Posted on Jan 19, 2010
I testified that the pin works great. I just spent 2 mintues to fix it.
Posted on Nov 15, 2008
On my oven you there is a small piece that is on the hinge itself that you must open with your finger when the door is on the oven to take it off. If your stove came off on one side like mine then it is easier to remove the door completely. Look at the hinge close to the door you will see a piece that can be pulled up. You must pull the hinge down and then open these peaces into place they will hold the hinge in place. Be careful the springs are strong. I used a channel lock to open the hinge. Then you just simply pick up the door and place it back on the oven. You must open the door all the way and then put the peaces back into place and your done
Posted on Oct 15, 2008
The nails worked like a charm! Thank you for posting this advice. I'm sure we would have wasted a lot of time attempting to fix this had I not had the forthought to look it up on this site!
Posted on May 31, 2008
Used solution no. 3, worked like a charm, if it took 5 minutes, it took a lot. Put the door over the edge of a table so the hammer can fully open hinge in 1 stroke. Nail works great, once installed they come right out. I played with door for 2 hrs, after internet search 5 minutes, should have looked first.
Posted on May 22, 2008
The solution above is perfect. If you use a pry bar, or the claws of a hammer, rather than a screwdriver it is very easy to pry the hinges open till you see a small hole where a small nail can be placed. Then the door pops right in!
Posted on May 02, 2008
  • pamslp7 Jun 26, 2011
    Thank you so so much! I had my two mechanical engineers working on it with frustration until they said Google it!!! It was in in less than 2 minutes! Thank you so much!! We still have fingers and are ready for happy baking!
Where can I get touch-up paint for the color Satina on a Whirlpool handle on a smooth top oven door?
Go to a "big box" retailer and get some sample strips that approximate the color. Take the strips home and find the best match for Satina. Return to the store and purchase a sample of the actual paint. Take it home and touch up the handle.
Jul 29, 2015 | Whirlpool Ovens
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
Power outageoven says stop the little button seems jammed wont push in any way around this?
i have the same problem. the oven was installed in my new house before i moved in, the display just says stop an the button doesnt click or anything? did you manage to find out what was wrong?
thank you
Jul 01, 2010 | Whirlpool AKZ159IX Oven
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 | Ovens
Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Jul 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
How to get the glass front back on oven door of Whirlpool range
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.
1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.
2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.
3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.
4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.
5: Replace door on Range Unit ande get cookin again!!
Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.
Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
Apr 18, 2009 | Whirlpool GBS277PDS Electric Single Oven
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven malfunction
I dont know how old yours is but there was a recall on whirlpool wall ovens due to the dor not closing enough and when in the clean cycle too much hot air was getting into the control panel and causing a thermal fuse to blow causing the oven to not operate. There is also a non resetable fuse in the back that will cause no operation of the oven. So if you did not have the shim kit installed along with a new seal you should call whirlpool and have your model and serial number off the unit to give them and the will tell you if yours needs the updated fix. If it needs it the repair should be of no cost to you.
Apr 01, 2007 | Whirlpool RBS275PR Electric Single Oven
Ovens Logo
10,605 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
