Gateway ne522 battery light blinks 5 times when I try to turn on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
3 Suggested Answers
  • 71 Answers
SOURCE: my new gateway 537nv will
If this is the case, i hope there is a problem in the power supply section. Go to the service center, & replace the Power supply of the laptop & try.
Posted on Jan 17, 2011
  • 483 Answers
SOURCE: Gateway laptop battery light blinks 5 times but won't power up
sounds like a bad battery
Posted on Mar 07, 2013
My Gateway NE522 laptop screen went black.I can't adjust the light level. I hooked it up to my 46" sony by HDMI and it works fine. is there a backlight or inverter for this model NE522 ? Rick
its more than likely the inverter went out. i suggest opening the bezel around the screen and get the part number off the old inverter. then check eBay for the replacement. should be no more than $10
good luck
Feb 24, 2017 | Sony Computers & Internet
How do I replace a keyboard on a Gateway NE522?
Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg
Replace Keyboard Gateway Laptop or
Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
5.November.2015
Nov 05, 2015 | Gateway Computers & Internet
Turn it on and light comes on but it blinks like 5 times after that it shuts down, each time i tried it did the same thing
take the battery out and unplug it wait a while then reinstall battery make sure your plug fully engages and no excessive wobble may also take a electric test meter and check out put voltage on power supply could have broken wire or shorted out or some one oopsed then forgot to tell you ie dropped it or pulled little plug out n dropped it in the dogs water pan whilst still plugged into wall socket as I have done if you can load test batteries as well as continuity might be bad batteries even new stuff can fail upon use the blink is a no power input/ dead battery signal you can try swapping batteries if another one is accessable if not 1800 gateway or gateway.com ask an indian if still under warrenty use it you payed for it also can power it up usb to usb with a lil engineering I think????????????????
Mar 31, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
My gateway ne522 keeps restarting every time i play a game
From what you describe it sounds like that the computer is overheating when you start a game. Here are some links with pictures to show you how to clean out your computer.
How to Clean the Inside of Computer : Desktop
http://www.instructables.com/id/Cleaning-Your-Laptop-Cooling-System/ : Laptop
Mar 19, 2014 | Gateway Computers & Internet
Gateway NE522
I have a cracked screen
Dec 26, 2013 | Gateway Computers & Internet
MD2614U will not turn on. red light blinks three times
The first thing to do is check that the charger is putting out the correct voltage, which should be ~19 volt. Then try to start it without the battery.If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
The dead laptop charger may be another cause. Try a new and correct one:
Intocircuit Gateway MD2614u AC Adapter 65Watt 19V 3.42A
Oct 30, 2012 | Gateway Computers & Internet
My new gateway 537nv will not turn on with or without the battery nor plugged into an outlet. The on light blinks 5 times and then goes out when plugged into the outlet. How do I turn it on?
Jan 17, 2011 | Gateway NV5378u Notebook
My nv5378u does not turn on, all i get is the battery light blinks 5 times. help please.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 26, 2010 | Gateway NV5378u Notebook
My montitor on my laptop went off last night, after messing with the mouse for a minute, i shut it off, now it will not come back on. when i hit the power, the light on the battery button in the front...
1. Turn OFF the Computer, remove the Battery and disconnect the AC Adapter also.
2. Press and hold the Power Switch for 5 seconds.
3. Insert the Battery in the Computer an try turning ON the Computer.
4. If the issue persists, remove the Battery, press and hold the Power Switch for 5 seconds.
5. Connect the AC Adapter and try turning ON the Computer(without Battery).
NOTE: If the Computer turns on without the Battery, connect and charge the Battery for 24 hours.
6. Disconnect all external devices that are connected to the Computer.
7. Attempt to turn ON the Computer.
8. Remove any additional Random Access Memory (RAM) that was installed in the Computer.
9. Attempt to turn ON the Computer.
This should resolve the issue.
If the issue still persists, then service may requires to resolve the issue.
Nov 22, 2009 | Gateway M-6843 Notebook
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
