Gateway ne522 series computer not turning on Battery light blinks 5 times when power button is pressed
  • Advaith Ganesan Dec 28, 2013
    Hi Jesse Beaudoin, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
5 Suggested Answers
  • 27 Answers
SOURCE: Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Posted on Feb 17, 2009
  • 1019 Answers
SOURCE: red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Posted on Jun 12, 2009
heavymetal77
  • 721 Answers
SOURCE: Gateway laptop model W350i will not boot. When
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Posted on Jul 14, 2009
  • 59 Answers
SOURCE: Gateway ne522 battery light blinks 5 times when I
This could well indicate a low battery and is merely a warning. Please read the attached link for the manual.
http://global-download.gateway.com/GDFiles/Document/User%20Manual/User%20Manual_Gateway_1.0_A_A.pdf?acerid=635035928994577078&Step1=NOTEBOOK&Step2=NE%20SERIES&Step3=NE522&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G
Posted on Dec 29, 2013
My computer is charging but the computer doesn't charge
The orange blinking light usually represents a dead battery. Check it out and see what happens.
Jan 08, 2014 | Gateway FPD2275W LCD Monitor
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
S/nLUWCX08006942365AC1601 WONT BOOT UP
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Gateway Computers & Internet
Gateway notebook wont boot up
Mar 30, 2012 | Computers & Internet
My montitor on my laptop went off last night, after messing with the mouse for a minute, i shut it off, now it will not come back on. when i hit the power, the light on the battery button in the front...
1. Turn OFF the Computer, remove the Battery and disconnect the AC Adapter also.
2. Press and hold the Power Switch for 5 seconds.
3. Insert the Battery in the Computer an try turning ON the Computer.
4. If the issue persists, remove the Battery, press and hold the Power Switch for 5 seconds.
5. Connect the AC Adapter and try turning ON the Computer(without Battery).
NOTE: If the Computer turns on without the Battery, connect and charge the Battery for 24 hours.
6. Disconnect all external devices that are connected to the Computer.
7. Attempt to turn ON the Computer.
8. Remove any additional Random Access Memory (RAM) that was installed in the Computer.
9. Attempt to turn ON the Computer.
This should resolve the issue.
If the issue still persists, then service may requires to resolve the issue.
Nov 22, 2009 | Gateway M-6843 Notebook
Feb 17, 2009 | Gateway MT3705 Notebook
I have a gateway m-6755 series laptop/notebook power issues
first press & hold power button for 6 second then again press power button to boot...
Dec 01, 2008 | Gateway M-6755 Notebook
Computers & Internet Logo
295 people viewed this question
David Payne
David Payne
