Question about Apple iPad Tablets & eReaders
Asus memopad me172v
I left my tablet with 10% battery after 5-6 hours i find it turned off and i assumed it wanted to be charged but the weird thing is even when i plug it to charge nothing happens , i tried several chargers and again nothing happens . the screen is black not even black light. I tried to hold down the power button for more tha 1 min and nothing happend, also tried volume +- and power button and again nothing happend... any suggestions?
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Posted on Nov 23, 2009
  • 84 Answers
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at
Posted on Apr 10, 2010
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
SOURCE: My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Posted on Dec 12, 2012
My RCA tablet wont charge I have to lean it against something to charge WHY??
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
Oct 17, 2015 - 50 posts - ‎43 authors
We often get questions such as " My tablet has stopped charging & I have .... Maybe the case was designed badly and the power button won't ..... Something must havelocked the Memopad open and ran the battery completely down. ..... I had RCA send a replacement tablet after it happened the first time.Missing: lean
Why can't I get my RCA tablet rct6077w2 charge or turn on ... > Get Help & Give Help! > Ask a Question
Oct 8, 2014 - 4 posts - ‎1 author
Screen will not light up at all. Took it to store, got brief charge there. At home, now, no indication of power.....Missing: lean
How to Calibrate Your Mac, iPhone, or iPad Battery ...
Mar 14, 2012 - The iPad and other tablets draw more current to charge quickly then a lot of other USB devices ..... Also, it's not something you should have to do frequently. ... iPad 2 will not charge shows battery in red with electrical symbol and plug symbols flashing on ..... I'd lean against trying to restore if it won't stay on.
My samsung galaxy tab wont charge at all, why? - Ask Me Fast > ... > Charge
Dec 06, 2015 | Tablets & eReaders
Can you fix a bad charging port on my asus memo pad 7
Asus seems to be having some serious issues with their memo pad and if yours is out of warranty doing it yourself may be your only option. There are a few videos on you tube about this problem so I would check them out. I had to open my Asus tablet when my cat knocked it on the floor and I had a black screen. Be aware that if you decide to fix your memo yourself that you need to be very, very careful every step of the way; take pictures, write notes...whatever you need. Good luck!
Aug 05, 2014 | ASUS MeMO Pad ME172V-A1-WH 7" 16 GB Tablet...
How to change top glass of me173x?
Asus MemoPad ME172V Take Apart and Reassembly Nothing Left This is the basic way its done.If you'd like i can do its for you.Call 225-290-5733
May 25, 2014 | ASUS MeMO Pad HD 7 ME173X-A1-WH 16 GB...
Why my tablet turns on when charging?
My ASUS Windows 8RT tablet is what I am basing this on, but it does the same thing. It's actually pretty common for the device to remain ON (standby) while charging. If you look at the battery icon, does it show anything different than usual?
May 17, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
My asus memo 7 inch tablet won't power up
This is a common problem with Asus devices. If the battery has drained completely, they don't like to come back to life.
Plug it in and leave it for a minute or so. Unplug the device, replug it, and hit the power button. The battery logo should appear, indicating that the device is powered off and connected to a charger. Now that the computer is awake (to display the message), hold the power button until the device powers up. You may have to hold the button down for up to 45 seconds.
Mar 31, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
Asus tablet owners manual/availability
Hope this link helps U... Copy & Paste the below Link in an browser
Feb 27, 2014 | ASUS 7" 1GHz Tablet w/ Android 4.1 Jelly...
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Asus memopad broken glass screen
I have the solution with a plastics tools can aopen it then remove the screws then remove only the touch screen failed and remplace it ! vote please
Dec 07, 2013 | ASUS MeMO Pad HD 7
Tablets & eReaders Logo
37 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
