Question about Craftsman Tractor Steering Knob
2004 y2000 6 speed manual, and the brakes are
2004 y2000 CRAFTSMAN LAWN TRACTOR 6 speed manual, and the brakes are failing, is there an adjustment? or how do I get these back?
  • 61 Answers
Look on the side of trans you will see a small
disc that is your brake there should be a 10mm or 3/8 nut there tighten this nut your brakes should come back.
Posted on Sep 07, 2009
Brake adjust need manual craftsman lawn tractor 917 257 620 manual
The manual for your mower is here: (5.08 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/LR707473.pdf
Brake adjustment is on the bottom left of page 20.
Thanks for choosing FixYa,
Kelly
Sep 18, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26HP Lawn Tractor Parking Brake
There is not an adjustment on the parking brake. The problem you are having may be caused by the drive belt stretching.
Jul 06, 2017 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust the speed control on a Craftsman 917.270921
Page 25 of your Owner's Manual gives step-by-step instructions for adjustment.
If you can not locate your copy of the Owner's manual that came with the tractor, go to www.searspartsdirect.com and download a copy of it. You can either print it out or save it to your computer for future use
Oct 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 brakes are failing
On the tranxaxle near the right rear wheel is where the brakes are located. There will be a rod going back to a lever. This lever will have a nut on it. Tighten the nut with a 1/2" wrench. With the transmission in neutral on level ground ensure the mower can be moved with slight resistance.
May 19, 2009 | Garden
Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Apr 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Tractor Steering Knob Logo
196 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
