Question about Vision Fitness T9200 Treadmill
Calibrate vision fitness 9200 - Vision Fitness T9200 Treadmill
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Jan 10, 2016
Jan 10, 2016 | Vision Fitness T9200 Treadmill
Tip
How to calibrate a Vision Fitness Treadmill - Residential Models
If you are not quite sure about the speed/elevation of your machine you can perform the following to test/correct your Vision Fitness treadmill.
1. Remove safety key and then replace
2. Hold the elevation up and speed down buttons until it beeps 3 times
3. If you see the model of your treadmill on this screen make sure you hold enter and then you will see "eng1"
4. Use the elevation buttons to scroll to "eng4" and hold enter to select
5. you should see the word "auto" on the screen at this point
6. Making sure you are not on the treadmill at all, press start.
The treadmill will go through a few tests to determine the maximum and minimum of both speed/elevation. You can see the results on the display as it is performing this test and if there are any discrepancies the machine will adjust the settings to make the appropriate speed/elevation calibration.
If the test passes it will display "end" and from here just remove and replace the safety key. You should notice a difference in the speed right away.
on Aug 05, 2010 | Exercise & Fitness
M tf40 vision fitness treadmill wont change incline or speed only just got today
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
see the diagram attached.
God bless you
Dec 18, 2012 | Vision Fitness TF40 Classic Folding...
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
Error lines in function area
adjust the reed switch, see the diagram attached , clean, and tight the wires very well.
RUN the software calibration for diagnose, and troubleshooting.
If you can not run the s. calibration and after you did the adjustment for reed swithc, tight the ribbon cable inside, then tight the connector from display board vs lower board. If the problem persist the display board is faulty or main motor board is faulty. RUN the s. calibration.
sincerly. God bless you
Apr 26, 2012 | Dmm Vision Fitness T9500 Treadmill
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
My vision fitness t9450hrt stopped mid run yesterday and the belt wont move..the inclene still works and everything else works fine i have took the cover off checked the drive belt from the motor and it is...
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
Apr 15, 2010 | Dmm Vision Fitness T9500 Treadmill
I have a vision fitness T9450 treadmill. My wife was using it and it slowed to 2mph. That is all the faster it goes now. Elevation controls work fine and everything else functions.
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Feb 06, 2010 | Dmm Vision Fitness T9500 Treadmill
VISIONEER STROBE XP22 SCANNER
WE DID NOT HAVE A "CLEANING SHEET" AS WAS SUGGESTED BY THE MAKERS OF THE VISIONEERS. APPARENTLY OURS DID NOT COME WITH ONE UPON PURCHASE. HOWEVER, WE WERE SUPPLIED WITH A CALIBRATION SHEET. WE SIMPLY RAN THE CALIBRATION SHEET AGAIN ...... PROBLEM SOLVED.
Nov 07, 2008 | Visioneer Strobe XP 200 Path-Through...
Vision Fitness T9200 Treadmill Logo
51 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Electro Med Services...
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
