Question about Pioneer PureVision Pro-800HD 43 in. Plasma HDTV
Pioneer elite pro 800-hd just blinking a 5 secon blinking red
The tv will act like it will turn on as normal then it shuts off with a blinking re light 5 times then contionues blinking.
  • 84 Answers
SOURCE: Pioneer Elite Plasma TV
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
Posted on Sep 20, 2008
  • 196 Answers
SOURCE: Pioneer Elite Pro 1000 HD
yes it can be definately repaired as this spark could be due to extra voltage passed throgh the tv circuit board from the electric outlet you r using.and the tv board was not able to handle that current and it sparked.
or it could also happen due to moisture collected on the board of the tv and the two electric components on the board got in contact due to the moisture and it gor sparked.
to locate the fault first check out the power cord wire is proper or got burned .if it is burned you will not get power.if it is proper then further check the fuse in the tv if it blows there will be no power.on the main power supply board there will be minute electrical components if they r burned or blown off this could be the problem.
if u dont habve any technical knowledge.call a technician and get irt repaired as the reparing will not be too costly.
this r common problem faced by many customers and get it easily repaired.
if this solution helps you.
please rate this solution.
thanks/.
Posted on Nov 05, 2008
electronick
  • 505 Answers
SOURCE: pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Posted on Jan 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Posted on Jan 28, 2009
  • 8457 Answers
SOURCE: Pioneer Elite Pro-111HD 50
Ur video ic inverter board is dead.
U need a new video board.
Posted on Aug 23, 2009
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Thomas
Dec 02, 2013 | Pioneer Televison & Video
Pioneer elite turns on then shuts off right away
Shutdown can be caused by many different things in the set. Do you get an blink codes from the power LED on the front of the TV? You can order boards and get help from the technicians from part suppliers I often use.
www.tristatemodule.com
www.rivervalleyelectronics.net
Nov 04, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer Elite 1140 HD not working : reds light blinks 4 times
Four blinks of standby light to Plasma TVs, denotes a voltage output failure from its main power regulator board. Check this link for more. http://electronicshelponline.blogspot.com/ Pull up older posts there. Blinking codes to most Plasma TV brands will be similar. Check them. Pioneer brand is also there.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I have a series of 5 blinks on my pioneer elite and need a number i can call for serves
1-800-421-1404
Hours of Operation:
Monday - Friday
10:00 a.m. - 7:30 p.m. EST
Please take a moment to rate :] Thanks!
May 09, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
TV will not power up. red LED blinking 5 times
I always found the problem to be either a combo of the x-sus printed circuit board and the y-sus printed circuit board. It is also very worth checking out your poer supply circuitry as well. Good Luck.
Aug 27, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer elite 50 plazma tv
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Sep 17, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer PureVision Pro-800HD 43 in. Plasma HDTV Logo
577 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
