Samsung hlr6167wx/xaa When the tv is on HDMI input, we get: No signal/weak signal. Other inputs work. Is it the board? Should we replace the digital board? Is it even available anymore?
tvtek
  • 1284 Answers
SOURCE: Samsung DLP HL-R6167W
Most likely the digital board will have to be replaced. Not a cheap part, so you might concider using the component inputs for now if too expensive.
Posted on Jan 24, 2008
Axle80
  • 73 Answers
SOURCE: No signal weak signal on only and both component inputs
Sounds like something isn't connected securely inside. Go back and recheck your cables, particularly the DVI cable. Report back if this doesn't solve your problem and we'll try something else.
Posted on Jul 02, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
  • 610 Answers
SOURCE: Replaced Digital Board on my Samsung HLR6167, picture is backward
call 1-800-samsung and they should walk you thru the programing, or they can help find the nearest service center.
Posted on Dec 01, 2009
SOURCE: My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Posted on Sep 05, 2010
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
HDMI inputs not working on plasma after lightening storm
The TV boards have got affected for sure. Might require attention by a qualified service technician.
Jul 29, 2012 | Panasonic TH-42PZ77U TV
My HDMI inputs no longer work. The other inputs are ok. I hooked in a dvd player with HDMI out to make sure it wasn't just my satellite receiver and still it just says no signal. What can I do? Thanks
The only solutions u can tries is to unplug tv,satellite receiver box and plug it back in like about an hour later for the tv to reset itself and the sattellite box receiver to reboot and upgrade it softwares.Than go into the tv Menu go into the video setting and reset the whole tv Tuner signal board.This solutions have great chance for all the HDMI inputs to work again.If not have the same problems,sorry than those HDMI ports on the tv Tuner signal board are shorted and dead.These HDMI ports are putting on by a wave soldering machine when they are put onto the board.These HDMI ports can't be replaced individually or buy parts for it,almost impossible to replaces parts by hand soldering equipments either.The only solution now only is to buy a whole refurbish tv Tuner for the replacement,if u have to have those HDMI inputs for your tv,can't used other inputs to handle ur tv need to functions the tv the way u wanted.U some mechanical skills,like can take thing aparts and putting it back together.Yes.Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jul 25, 2011 | LG 42PG20 42 in. Plasma HDTV
The HDMI inputs on my tc-p50x1 will not work at all. Both component inputs work, but all three of the HDMI seem to get no signal. Is there a fuse I can replace, or do I have to replace the entire...
No,the HDMI connections hubs are just a few small components parts that was put on by the wave soldering machine and it is on and surface mounted by soldering fussion to the tv to main tv Tuner signal board and funsction as one board,can't replaces these HDMI hubs by itself,it very hard and almost imposible to do so by hand soldering equipments and these HDMI components hubs they don't sell out as individual consumer parts any way.Tries tv unplug,replug it back like about and hour later for the tv to do a resetting itself back to the factory setting.Than go to the tv menu go to PICTURE setting go down to do a resetting to do a resetting to all the funsctions of the tv Tuner signal board.Now all ur HDMI hubs should be working again.If not,the whole Tv Tuner signal board mut be reolaced.Try website like Ebay.com to buy a whole refurbish main tv Tuner signal board for the replacement.
Apr 07, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Jan 23, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
