Lg 42le4500 HAD NO PICTURE BUT SOUND NOW I HAVE NEITHER
  • LYNDEN JONES
    LYNDEN JONES Dec 30, 2013
    I have an LG42LE4500. The tv picture started to on and off but with sound. Then it went off altogether with neither picture or sound. pulled the plug to reset but still no good. i've taken the back panel off and give it a visual. all the caps seem fine on the power/inverter board although i have not tested them yet. Need to get a tester.the set powers up ok and the white light stays on but nothing on the screen, just black, no glow or nothing. Could this be a chip in the main board?
2 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Posted on Jun 26, 2012
LG 42LE4500 ZA no picture
1 or 2 condensed broken check it better in YouTube can see better with images
Dec 30, 2015 | LG Televison & Video
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
Jerry G.
Jun 25, 2012 | LG Televison & Video
I bought a lg 42le4500 led/lcd tv and hooked it up to my v+ box via a hdmi lead, but picture is a bit fuzzy is there somthink i can do to sort this?
Check the setting on the V+box for a HD setting hook up should improve the picture.Still have the same problems,the HDMI cable it is the problems,changes another HDMI cable
May 10, 2011 | LG 42LE5400 42 in. LCD TV
Please could u help ime looking for a manual for a LG 42LE4500 LED TV Thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 02, 2011 | Televison & Video
Just bought a 42LE4500 model. Picture looks blury during fast movement. It appears the system is not processing the picture in time.
This model has just a 50Hz refresh rate and so this is a known problem. Try and view it from the recommended distance of 3 times the TV diagonal width ; the effect of this problem will be vastly lessened.
Nov 27, 2010 | LG 42LE5400 42 in. LCD TV
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
