Question about Refrigerators
How do you remove the fridge light cover from Samsung RL38SBSW
4 Suggested Answers
SOURCE: recently bought a samsung rl38sbsw
I have the same freezer and it's normal for the sides to be warm. I've had mine for over 3 years so yours is working fine.
Posted on Jan 03, 2009
kel1guy2002
  • 3740 Answers
SOURCE: we have a Samsung fridge
There are 2 tabs that you press from the fat tabs to loosen it. The tabs are about 3/8" wide and you just squeee the tab from the tabbed area with your thumb. Once the large part tabs is released, you pivot the cover up about about 40 degrees and remove the light cover.
The bulb is an E14 base "screw in" type bulb.
The lamp cover is 2.99 Euros.....
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=2238373&query=Samsung%20RL38SBSW&model=RL38SBSW&path=67607,111066:67610
Stock number 5045-1763-4869-8
Thanks for choosing FixYa, Kelly
Posted on Sep 22, 2011
  • 884 Answers
SOURCE: Westinghouse Aurora RJ442 how to remove the cover of the light inside the fridge?
A flat driver between the plastic cover and the fitting will lift the edge. Gently pull outwards and the tabs come out
Posted on Apr 28, 2012
Where is fuse in samsung srs626hnss
Is there no power? What are the specific problems?
Jun 05, 2016 | Samsung Refrigerators
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Samsung Instructions
look for scews around cover if no scews the some covers you squeeze an pull apart
Oct 18, 2013 | Refrigerators
We have a Samsung fridge freezer we have lost the manual , the nunber is RL38SBSW 11.3CF. The problem we have is that the inside light has stopped working and i cannot work out how to get cover off to...
Sep 22, 2011 | Samsung Refrigerators
I need a user manual so I can set temp for FFmodel no RL38SBSW
You could download the manual from :l-
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/RL38SBSW-_E
You need to have acrobat reader to view the files.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 13, 2010 | Samsung Refrigerators
Select light on
Check the fridge cooler unit behind the cowlings inside. The problem is you have to empty the fridge. Remove the light cover by pulling it away and remove both screws. Take the unit out after removing the connections. Simple clips that will fit back only one way. Remove the lowar covers from the fan housing and take out the four screws. Ease the unit away breaking the ice seal. Defrost with a hairdrier or similar and repeat on the fan unit you have removed. Clear away some of the insulation from the fan drain and when dry and clear re assemble. Good luck. By the way it has to be done whenever you hear the fridge fan founing. Paul.
Jul 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Recently bought a samsung rl38sbsw fridge freezer it worked or 24hour Then side got really warm is this normal?
new new code...
5a 01..
3F 32 37 03 D0 73 84 84...
C6 64 1D EF 47 5A 0E EF.......18.55PM
Nov 18, 2008 | Refrigerators
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
468 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
