Question about Daewoo Refrigerators
Frg2170bns need to know where the thermostat is located
Thermostat location
The Thermostat is located just above the main crank pulley just to the left of the water pump behind the pulley belts and timing belt covers. its usually a 180 degree F. thermostat.
Mar 09, 2014 | 1994 Nissan Pickup
Location of thermostat in Dodge Dakota 2000 4x4, 6cylinder, 3.9
The thermostat is located on the rightside of the truck as viewed from the drivers seat. Follow the upper rad hose it connects to the thermostat housing. A good way to check if the thermostat is stuck is when the motor running and fully warmed up squeeze the hoses if it is hard then the thermostat is stuck. Another way is with the motor hot feel if the upper rad hose is hot; if it's not then your thermostat is stuck. Hope this helps.
Mar 01, 2013 | Cars & Trucks
Where is the thermostat on 1997 GMC Sonoma located?
Click here to see how to replace the thermostat.
Jan 20, 2013 | 1997 GMC Sonoma
I need to know where the thermostat is located for the Audi A8 V8 4.2 Quattro Automatic 2006
The thermostat is located in front of the engine, between V cylinder banks, for Audi A8 V8 4.2 Quattro Automatic. See pictures below:
Remove the thermostat housing (2 bolts) and the old thermostat. Note the orientation of the old thermostat (vent valve facing UP). Clean both thermostat housing and block surfaces and remove all traces of old gasket material. Install the new thermostat vent valve facing UP.
Please do rate my response. Thanks!
Dec 26, 2010 | 2000 Audi TT
Check engine light is on . need to know where the thermostat is located
The thermostat is a black plastic water outlet housing connected to radiator hose. when replacing the thermostat the whole housing is replaced.
Nov 28, 2010 | 2006 Ford Fusion
I need to know the location of the Thermostat on my 1996 Jeep Grand Cherokee,
If you have a V8 the thermostat is located under the coolant inlet tube. The tube is located on top of the engine, in the front about center. The thermostat is hard to change. Locate the upper radiator hose on your radiator and follow it to the engine block it is located on the top front part of your engine and you must lean over the front and look down onto the block to see the thermostat housing.
Oct 29, 2009 | 1996 Jeep Grand Cherokee
Where do i locate the thermostat on my 94 scoupe?
Follow top radiator hose and it will lead directly to thermostat housing. Housing should have 3 bolts on it. Thermostat is under it.
Oct 29, 2009 | 1994 Hyundai Excel
Need location on thermostat
Follow the top radiator hose to the engine and you will see it's attached to the thermostat housing, simply undo the bolts and you will see the thermostat.
May 15, 2009 | 2000 Mitsubishi Galant
I just need to know the location of the engine thermostat on a 93 mazda mx6
If its the v6 it is located on the right side of the motor just follow the top right radiator hose to the case the thermostat is located in.
Apr 25, 2009 | 1993 Mazda MX-6
I need to know how to locate the thermostat in my 02 durango.
the thermostat is located in a housing with usually 2 bolts holding it to the engine and a gasket, follow the top radiator hose down to the engine and you should find it
Mar 23, 2009 | 2002 Dodge Durango
Refrigerators Logo
43 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
