Question about PNY Attach? 16GB USB 2.0 Flash Drive
Not recognized The camera didn't work with the memory, the message it show's is to turn off or format the memory, but when i put "format" doesn't work
    Champion:
  • 221 Answers
It showed that the memory card has bad sectors try fixing it by typing "chkdsk x: /f /r" (x is the memory card) then press enter at the command prompt on your computer
Posted on Dec 31, 2013
After inserting an approved memory card the following message shows up 'Memory card error' - what to do?
Try another new memory card, if it continues to give you an error go to the main menu and look for FORMAT, some times you need to format the card so the camera can recognize the new card.
May 24, 2014 | Canon PowerShot SX20 IS Digital Camera
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Put memort card in camera,,didn't realize I had to format disc.followed instructions in book to format but does not tell me it is formatting,,, still get unsupported card message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 27, 2011 | HP Photosmart M417 Digital Camera
I have Panasonic Lumix FX9 and I have an original 16mb memory sd card that is working but when I put another card the camera says "memory card error please check tha card" and I don`t know what...
Welcome to FixYa.
One possible reason why do you get a "memory card" error is because the memory card is not yet formatted for camera use. Try to format the memory card using the camera itself. Do not use another camera or PC's when formatting the memory card,it may cause another error because it will not recognized by the camera.
Try also to clean the memory slot by using a soft and dry cloth. Then turn on the camera again.
If the message still persist, you neen to contact Panasonic service center.
Please let me know if you have any questions or if this solution was helpful.
Thank you for using FixYa.
Apr 15, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
I put SD card in the camera but the camera doesn't recognize it. It always use the internal memory which is so small in capacity so I always get the message memory full. What do i need to do? Usually it is...
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. After that, your card should work.
Nov 16, 2010 | Nikon COOLPIX S8 Digital Camera
When i put the memory card in my samsung SC-DX103 digital camcorder the message reads"card not supported" Someone told me i have to format the memory card on the computer. i have no idea about this and...
Most memory cards are pre-formatted and should work out of the box. Somehwere in settings menu is the ability to FORMAT or you could use a card reader on your pc ( this will show up as an additional drive letter ( (E)) or whatever and then selct it and get the PC to format it ( R click or from FILE) option on top Menu of file explorer.
If it still does not recognize the card take the card and your camera back to the place where you purchased the card and let them look at it
Jul 22, 2009 | Cameras
Acer 5920 does not work with sandisc 1gb memory card
Your Minolta camera uses file format, which is not recognized by PC and vice verse. When you insert, PC can't read it, and asks to format. But when it is formatted for PC, your camera can't read it. Try to format it in camera, if it's not possible, then get a new memory card and use USB cable to copy images.
Feb 15, 2009 | Acer (AST135-U-S3100) PC Desktop
I'm needing a driver for my FE-280
I went to Olymbus website to find the driver for the FE-280 Digital camera and it states, no software availble at this time.
They show the camera on the website and I know there is a driver for it, but they are not supplying the consumer with it. Bad choice for Olympus.
I have given you some information and links below:
http://www.olympusamerica.com/files/FE-280%20Instruction%20Manual.pdf
This is the manual for your camera.
Go page 45 at the very bottom. Using a New Card
The FE-280 does not recognize my memory card. What can I do?
First, refer to the xD-Picture Card™ Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
The FE-280 may not recognize non-Olympus brand media or a card that has been formatted on another device, such as a card reader or personal computer. As a general rule, xD-Picture Card media should only be formatted in the camera. Card readers should only be used to copy files from the memory card to an external device.
You may be able to use the card if you format it in the camera.
Warning: Formatting a media card will delete all content on the card.
When I put an xD-Picture Card™ flash memory card into my camera and turn it on, I get a “Card Error” message. What can I do?
This message occurs when the camera is unable to recognize the memory card or when an attempt to format a card fails.
If you see this message after inserting a brand new card, refer to the xD-Picture Card Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
If the card is supported, it may need to be cleaned. Wipe the gold contacts of the card with alcohol using a soft cloth or tissue. When the contacts are dry, insert the card and turn the camera on.
If the Card Error message still appears, remove the card and insert a different supported card into the camera. If the camera reads the second card, then the camera is working properly and the problem lies with the original card.
If you receive this error message after a failed attempt to format the memory card, the card may be defective. For assistance, contact Olympus’ Customer Service and Repair Center using any of the following methods:
Phone: 800-622-6372
http://www.olympusamerica.com/cpg_section/OM_UpdateSoftware.asp
This is about updating the olympus Master Software.
If I can do anything else for you let me know
Mar 29, 2008 | Olympus Stylus 800 / ? 800 Digital Camera
PNY Attach? 16GB USB 2.0 Flash Drive Logo
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
