Question about Android Cell Phones
How long for initial charge?
I thought it was supposed to be really fast. It's been charging for at least 2 hours. Is it working? Red light still on.
  • kakima Dec 28, 2013
    What make and model Android cell phone?
    Habit-Forming:
  • 84 Answers
Usually for the first charge, most electronics require a 24 hour charge. Unless they come fully charged and ready to use. Check your manual.
Posted on Jan 07, 2014
5 Suggested Answers
z_thompson_z
SOURCE: charging error, stop charging! with "!"
I have had this problem before so dont worry, i found that i had to take out the chip and batery and air it out aswell as the the place were the charger fits, place them back in and try to charge up again.
Posted on Dec 28, 2008
  • 512 Answers
SOURCE: The battery is discharged very fast and phone is hot.
Battery should be warm after charging, if it is hot, it could be defective. Add that to the short life and I'm going to advise you to get a new battery because it sounds like a cell or two inside has shorted. Can't be fixed, dispose of bad battery properly please.
Posted on May 17, 2009
walesarumi
  • 6993 Answers
SOURCE: battery drains very fast
First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
I wish you the best.
Posted on Dec 08, 2009
  • 270 Answers
SOURCE: i have a new blackberry 8520 gemini unlocked.
Hello
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Posted on May 12, 2010
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
What color is the light suppose to be when my pyle pro pwma600 pa speaker is charging suppose to be green or red?
Hi,normaly the green light says that the battery is fully charged,so if its red it might be that its charging but not fully charged,but saying that if it dose not charge after some time then the red light can mean its not charging,just food for thought,all the best.
Oct 02, 2015 | Cars & Trucks
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
Jul 20, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Roomba Schleduler Charging
Bad battery most likely. Could be a faulty charger too. Have your local vac shop test it.
Jun 07, 2017 | Roomba Vacuums
02 Chevy Cavalier - Fast Clicking Noise When I Turn Key
your battery isnt holding enough charge to crank the starter.thats what the clicking is. try charging you battery for a good 8-10 hours, if it still does the same thing you'll need a new battery.
Nov 02, 2009 | Chevrolet Cavalier Cars & Trucks
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Video camera jazz dv179 how many hours need to charge
I HAVE THE SOLUTION!!!!! the camera comes with a charger that plugs into the wall and into the usb port on the camera
Oct 27, 2007 | Jazz DV-179 Digital Camera
Cell Phones Logo
18 people viewed this question
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
