Question about McCulloch Garden
Starts with spraying gas into the carb then quits
Starts with spraying gas into carbrator then quits
You have spark, so problem with fuel. Maybe old gas. Determine if getting fuel to carburetor - if so you need to clean carburetor. If not, clean fuel lines or replace fuel pump.
Posted on Dec 28, 2013
14 inch chain saw carbrator type walbro
you need the numbers off the carb in order to get either a carb kit or a replacement carb. Once you have the carb # its easy to find the proper kit
Oct 12, 2014 | Garden
Honda 5.5 air compresser will only starg on full choke , then dies as soon as touch choke , drained all gas and cleaned carbrator, finally unhooked electric ignition and spring that's on the back of the...
Theres a clogged main jet orifice.. take carb off and check all passages- pass some fishing line through them to clear. Seen this before and THAT is te issue
Sep 08, 2014 | Motorcycles
My tractor mower wont start ,it will turn over but wont start
the carb may need rebuilt .try spraying some choke cleaner in the carb and try starting it , if it runs for a second and quits its the carb. or it could be bad gas.
Jan 31, 2013 | Garden
I left fuel in my 97 25hp mariner and now it won't start. how do i get the bad fuel out of the carbrator. I cleaned out the fuel filter and when and got some new gas and 2 cycle oil and bought some...
The carb needs to be removed, taken apart so it can be cleaned. after sitting, the gas will gum up the inside and stop up the jets. Also, it's not a good idea to use starting fluid on a 2 stroke engine.
Sep 02, 2017 | Boating
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Chevy tahoe wont start its as if its not getting gas
If you think it is not getting gas, then it may not be. You would need to verify this by installing a fuel pressure gauge. This truck MUST have at least 55 PSI. Even a few LBS less, the truck will not start.
If you do not have pressure, or it is low, a plugged fuel filter or faulty fuel pump would be the most likely problem. If no pressure at all, a quick test to check the fuel pump is to have someone in the truck trying to start it, and you go under and bang on the gas tank with a hammer. Many times this will free up a sticking pump. But, it will fail again.
Jan 23, 2010 | 2001 Chevrolet Tahoe
Herohonda bike starting problem
Your bike has a carbration problem in that it has debris in the carb. What you must do to correct this is completely remove the carb, then take off the float bowl. it is on the bottom of the carb and is rectangular with 4 phillips head screws. once the screws are out, lightly tap the bowl with the handle of your screwdriver to get it loose. Empty this bowl (it will be full of gas/water/junk) and wash it out with new clean gasoline or a spray carb cleaner form the auto parts store. There will also be two jets in the center of the carb, they are gold in color. spray these out with the cleaner or compressed air. The holes in them are very tiny and must be cleared out. Once you have this clean, reassemble and the bike should run like new. If the gas tank has any debris in it, this problem will come back unless you install a filter. best wishes!
May 11, 2009 | 2006 Hero Honda Splendor+
Starting Problem
I am not familiar with your bike but if it has a standard carburetor then remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Install a new stock NGK spark plug.
Remove the carburetor from the engine. Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Please rate this solution. Thanks!
Apr 23, 2009 | 2006 Daelim Daystar
My dirt bike quits running as soon as you turn off the choke
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Apr 21, 2009 | 2004 Yamaha TT-R 125 LE
2001 raptor cabs not getting gas
MAke sure your tank vent is clear.If so you need to pull the carbs and clean the passages and jets.You may have a stuck float or needle
Feb 08, 2009 | 2003 Yamaha WR 450 F
Garden Logo
32 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
