Question about Janome Memory Craft 9000 Computerized Sewing Machine
Machine does not stop
Occasionally machine does not stop. Foot control tests OK.
  • Janome Master
  • 1,388 Answers
Foot Control is metal... White non-retractable ??
We probably have a solution for you here
Instant Download Solution for Sewing Machine DC foot control pedal not...
Posted on Jan 14, 2014
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
I have a Janome DC 2010. The machine has started to continue to sew even when my foot is off the foot control. I turn the machine off and then back on and it goes to error message fc....then goes to...
my book show the FC stands for Foot Control
have you tryed repluging the foot control into the machine to see if that stops the problem
if you have & it didn't stop the problem
then I agree you need a new foot control
Sep 27, 2010 | Janome 2049LX Mechanical Sewing Machine
Light is on but won't sew
Sounds like either the foot control or the motor has failed. The foot control is the easiest to replace, you should be buy a replacement control for about 30.00.
May 25, 2010 | Janome Harmony 9102D Mechanical Sewing...
I checked out my machine and everything seems to be intact. The machine is plugged in the machine's light is on but it's not getting any power from the foot pedal. I don't know what to do. Please...
If foot pedal alows you to control the speed of the machine. They do go bad occasionally. If your machine motor plugs into the foot pedal unplug it and try it in a wall outlet if able. This will tel you if the machine motor is good or bad. Plug a lamp with a regular bulb(incandesent not flourescent) into the foot pedal. As you press the pedal the bulb should get brighter. This will tell you if the pedal control is good. Be sure the lamp is in the on position
Thank you for contacting Fixya.com
Nov 22, 2009 | Kenmore Sewing Machines
There is power to the foot control but not to the machine to make it sew
If foot pedal alows you to control the speed of the machine. They do go bad occasionally. If your machine motor plugs into the foot pedal unplug it and try it in a wall outlet if able. This will tel you if the machine motor is good or bad. Plug a lamp with a regular bulb(incandesent not flourescent) into the foot pedal. As you press the pedal the bulb should get brighter. This will tell you if the pedal control is good. Be sure the lamp is in the on position. If this is helpful, Please leave Feedback.
Thanks, SnugglePants
Oct 21, 2009 | Sewing Machines
Old model Bernina 830, running ok, then kept running, won't stop. disconnected cord, disconnected foot control, plugged cord into motor, motor runs without foot control. Reconnected foot control, motor...
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Jun 25, 2009 | Bernina Sewing Machines
Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Feb 02, 2009 | Sewing Machines
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Mar 12, 2008 | Husqvarna Freesia 425
Janome Memory Craft 9000 Computerized Sewing Machine Logo
85 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
