Question about Fishman Music
Unit inoperative, one LED blip on battery install only.
Martin Guitar with a Fishman Classic4. New 9VDC battery installed, LED blips once only. I can slide the Fishman out, squeeze the battery tighter to the connections (assuming it was too loose) and same - only one blip. I even went as far as removing the whole unit from the body of the guitar in order to wiggle test, tap, squeeze anything, and still the same - one blip only and can hear a faint pop in the Amp that the guitar is plugged into. i am pretty handy and knowledgeable in electronics and am suspecting an internal problem in the Fishman's IC board/components. Thanks in advance!
  • 2 more comments
  • Brad
    Brad May 19, 2009
    Update:
    The single "blip" is normal:
    Low Battery Light
    This light has two distinct functions:
    1. Power Up Indicator
    The low battery LED will flash briefly when you plug in your guitar. Some people ask us, "why doesn't this light stay on, like a conventional pilot light?" We believe that a steadily lit LED devours too many precious hours of battery life. Since the light flashes briefly only when the unit turns on, battery power is conserved and battery life is extended.
    2. Low Battery Warning
    When the Low Battery LED lights steadily, it is time to change the battery.
  • Brad
    Brad May 20, 2009
    Thanks.
    I tested out the cord (was fine) re-soldered and re installed it. I tested out the marshall amp and found the acoustic input is dead. (aux input is fine and all works there) Off to shift my attn to the amp board & jack!
  • Brad
    Brad May 23, 2009
    Update:
    After re installing the Fishman, I checked output on an oscilloscope - signals out looked good. I went to the Marshall amp and found the culprit - acoustic input jack - one leg was broken off the circuit board. Swapped with Aux. input jack (not used) and all is well.
    Thanks all.
  • rjivaro May 11, 2010
    Before you tear into the circuitry, try using a different guitar cord. Stranger things have happened. :)
    President:
  • 1,137 Answers
Its possible that if you changed strings the saddle might have changed position in its slot. It has to sit uniformly on top of the piezo element in order to work properly. Try testing the pickup(piezo element) first before suspecting the preamp.
Posted on May 23, 2009
It is not a problem yet, but how do I connect a Fishman Triple Play to my acoustic guitar
with most add-on products like this, they would be self adhering. I suppose if you want it there permanent, a bit of glue.
Jun 26, 2012 | Music
How do I open the battery compartment on the oooCXE
The little latch is above the word "Fishman" right in the center top of the tuner. With a fingernail, pull the latch toward the center of the tuner and the whole thing pivots out exposing the batteries.
Jul 20, 2011 | Martin Guitars Martin X Series: 000CXE...
When I connect the onboard Aura via USB to my computer and open the Aura imaging software, it doesn't recognize my device and a fishman product..... HELP!
You could call Martin Guitars at 1-888-433-9177, or visit their website:
http://www.martinguitar.com/contact
And/or try Fishman:
http://www.fishman.com/contact
Although they don't have a recognizable toll free number, they do have an online form.
If you have access to support for your computer, you could try that, instead.
Good luck, and I hope this helps!
Jun 29, 2011 | Martin Guitars Martin 000C-16RGTE Aura...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
How do I tune guitar using intergrated fishman tuner as I have no instructions.
With good battery in the unit. Press the TUNE button. This will disconnect the audio output while tuning. The indicators on the tuner will show the note, including sharps or flat and there will be a red arrow either >
Jan 15, 2011 | Fishman Music
I bought a Martin DC16GTE last year in Germany, brand new. (Music Store, Cologne) My Fishman prefix premium blend has a tuner build in. It tunes properly, but once activated, I can't turn it off by...
Most devices using a button to turn them on off SEEM to require HOLDING the button down for a bit (few seconds) to make sure you really want to turn the device off...
Dec 16, 2010 | Fishman Prefix Premium Blend Preamp -...
The pick up on my son's Martin LXME won't work
Take it to a guitar shop and have them check out the soldering and connections within the guitar.
Martin has a record of cutting corners on their less expensive models.
Jan 13, 2009 | Martin LXM "Little Martin" Acoustic Guitar
Music Logo
869 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
