Question about Sewing Machines
Part for a De Luxe SWM 1000
Need part no 25 zigzag cam with screw gear
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
Empisal celebrity 550 manual- My Empial Celebrity 550 stopped its zigzag function.Please help?
contact a1sewingmachines.com and ask them about a manual
it's possible that the zig zag function has stopped is the gear or cam may be so worn or broken that the machine needs to be checked to see if it need to be replaced..
Sep 10, 2013 | Sewing Machines
Dressmaker sewing machine model SWM-1000 deluxe
Is there another name on the machine like Euro-Pro?
I find a 998 and a 1100; no 1000 in Manuals.
Below is another list of the Model Numbers:
Dressmaker Sewing Machine Manual PDF and CD
May 11, 2013 | Kenmore Sewing Machines
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
Dropped stitches on zigzag only
make sure all the levers are set correctly for zig zag stitch
change the needle
it's possible that a gear or cam is damaged & the machine needs to be checked
Apr 10, 2012 | Singer Sewing Machines
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Zigzag stitch only stitches on the left side.
if the zigzag stitch only stitches on the left side it's very possible that the cam or gear inside that does the zigzag stitch is either worn out or broke or damaged in some way, only a repair shop service tech can tell
Aug 26, 2011 | Simplicity Denim Star SW210
Bernina 730 cam gear replacement and alignment
It does not matter where the position of the camstack is when you put it in, it should not affect any other part of the machine.
Jan 30, 2010 | Bernina Bernette 75
Singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Jan 13, 2010 | Singer 2662
Sewing Machines Logo
11 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
