Question about Euro-Pro Dressmaker 998B
Need parts for a De Luxe SWM 1000 sewing machine
Part no. 25 zigzag cam with screw gear replacement part? Know how to get one?????
Trouble shooting
the reason why the zig zag no longer works is a gear or cam could be damaged or broken
Jul 11, 2014 | Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
I can't get the zigzags to work on my White Sewing machine Camamatic #502
the gear or cam inside the machine maybe worn or broken, it would be a good idea to have the sewing machine checked at a sewing machine repair shop.
Aug 02, 2013 | White Sewing Sewing Machines
Dressmaker sewing machine model SWM-1000 deluxe
Is there another name on the machine like Euro-Pro?
I find a 998 and a 1100; no 1000 in Manuals.
Below is another list of the Model Numbers:
Dressmaker Sewing Machine Manual PDF and CD
May 11, 2013 | Kenmore Sewing Machines
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
Bernina 730 cam gear replacement and alignment
It does not matter where the position of the camstack is when you put it in, it should not affect any other part of the machine.
Jan 30, 2010 | Bernina Bernette 75
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Machine will not zigzag
The guy is right, dust kills the moving parts. try oiling the shaft that holds the needle up about 1/2 way and then run on straight stitch with no thread to work in oil, do this several times till you feel that it runs smoothly and you have a little movement side to side as this is necessary for your zig-zag. if that does not work it may be a cam or belt in the top part that needs replacing and you will need the repair to tell you that. I asked them to give me a quote before any work was done so I knew what I was up against. I love my machine so it was worth the 200.00 to get the parts replaced. It will sew anything cause it is a older model with metal rather than plastic parts. hope this helps good luck
Jun 17, 2017 | Singer 3116 Simple
Euro-Pro Dressmaker 998B Logo
37 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
