Question about Hoover HDC6 Electric Dryer
My hoover VHC691B-80 condenser tumble dryer starts but doesnt heat up.
After a few minutes running, it stops. All the red lights then flash. I have changed the element which has not solved the problem.
  • 1462 Answers
SOURCE: tumble dryer
take the top off. there should be a small relay board to the right just behind the fascia. the fault probably lies in that board - relay not holding in
Posted on Apr 04, 2007
dididsaythat
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
SOURCE: I have a hoover Nextra
My nextra has just started to do same thing, does anyone know what is wrong
Posted on Jun 11, 2008
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
Vhv680f tumble dryer, put on a cycle and it works for a few seconds then all lights start to flash and it stops
Could be a few things, start with the sensor, then heat element, thermostats, and finally the electronic board, need to use a multimeter.
Dec 23, 2009 | Hoover Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Hoover HDC6 Electric Dryer Logo
106 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
