Question about AEG L74650 220volt 50hz 7 Kg Capacity Washer-16224
EH10 WHAT DID EH10 MEAN
Getting ramdon err code on display et100c timer
Change battery that is located in pull-out tray just beneath the buttons.
And then reset timer, then re-program timer.
ET series and EH series have battery:
http://waterheatertimer.org/images/EH-10-battery-carriage-350.jpg
If timer function is not restored, then timer has gone bad.
Replace with 120 volt EH10 timer.
http://waterheatertimer.org/How-to-wire-EH10-water-heater-timer.html
ET100 series Timer has 1 year limited warranty, and is discontinued, but may still be available. Not recommended to buy used timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET100
Oct 02, 2012 | Intermatic ET100C Energy Controls -...
I have a timer that won't hold the program time set schedule? I have paid an electrician to come out and check to make sure i don't have any shorted out wires?? Electrician didn't find any...
Question posted under 120volt Intermatic Eh10 timer.
I do not have repairs for defective timer.
EH10 has 1 year limited warranty.
Located just below the digital display is compartment for AA battery.
Display is controlled by battery.
Replace battery, press and hold reset button for several seconds to reset timer, and try to program again.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#EH10
http://waterheatertimer.org/pdf/eh10-manual.pdf
EH10 and EH40 timers are susceptible to line noise.
If timer is connected to water heater, there is no line noise. And electrician tested for shorting wires.
But when timer is connected to fan, pump, or other type of load, then interference can be a problem.
Intermatic can provide a filter.
http://www.intermatic.com/customer%20service.aspx
Digital timers, digital water heaters, digital washer and dryer, digital water softener, digital treadmill, etc are increasingly common, yet are not protected from surge.
People protect computers and TVs, but forget other costly items.
EH10 can be affected by surge.
Install whole house surge protection:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Aug 17, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Have been in our home for 25 years. Paragon 4001-00 is located at top of stairs, right outside of our bedroom, and we have no idea what it controls. No lights come on automatically, either outside or...
Find the circuit breaker that operates the timer.
Turn off that breaker.
Open the timer box.
Disconnect black wire from terminal 1 screw, and put wire nut or plastic tape over end of wire.
This will stop the timer, and then you can see what the timer is used for by watching what is not working.
Is the timer connected to a water heater?
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
If timer is connected to water heater, move black wire that was connected to terminal 1, and connect it with wire on terminal 2. This will by-pass the timer, and the water heater will be on all the time.
If you need new timer that makes less noise, then buy electronic timer.
Paragon 4001-00 is simple 120V timer, so replace with Intermatic EH10 120V electronic timer.
Amazon sells EH10:
http://www.amazon.com/Intermatic-EH10-Electronic-Heater-Indoor/dp/B000GHIPOA
Please add a comment for more detailed information.
I have extensive knowledge of these timers, and can help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
ET70115C $379
http://www.1000bulbs.com/product/3391/ELEC-ET70115C.html
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
Intermatic ET1105C $96
http://www.amazon.com/Intermatic-ET1105C-Hour-Electronic-Switch/dp/B002X1FYWI
Intermatic ET101 $101
http://www.westsidewholesale.com/24-hour-programmable-electronic-timer.html
Tork EW100B $177
http://www.1000bulbs.com/product/8434/TORK-EW101B.html
Sylvania SA300 $72
http://www.amazon.com/Sylvania-SA300-120-Volt-Single-Pole-Industrial/dp/B000KKNEO4
8) See wiring diagrams and manuals for some of the timers listed above:
http://waterheatertimer.org/Boxtype.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Timer loses program and time. Flashes wrong time. No power loss, already replaced battery. Any ideas? Jerry
1) Reset the timer.
Sometimes this works, sometimes it doesn't and timer has gone bad.
Manual for EH10
http://www.1000bulbs.com/pdf/Inter-EH10-EH40-Operating.pdf
2) Manual says:
"If the display
has scrambled information, check to be sure that
the polarity orientation of the battery is as shown on
the cover label, then press the RESET switch and hold
for at least two seconds."
3) If display shows, then contacts are good.
EH40 and EH10 have same battery carriage.
4) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Why do I need to use the Jumper? Does the timer close the circut on the nutrel side only or does is close both ?
EH10 has four screw terminals: 1 2 3 4
EH10 has two screw terminals exclusively for electronic clock motor.
These terminals connect exclusively to clock ... there is no internal jumper that passes power to another terminal.
Terminals 2 and 3) Black Hot lead connects to two terminals. Hot connects to terminal 2 and to terminal 3 ... so you put a jumper wire between terminals 2 and 3.
Terminal 1) All neutral or white wires connect to terminal 1, so there are two white wires on terminal 1.
Terminal 4
) Black wire going to 120V Load connects to terminal 4.
Contrast EH10-electronic-timer with T-101-electro-mechanical-timer. T-104 clock motor has two separate wires that connect to terminals A and 1. Electronic clock doesn't have those separate wires.
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Your second question about closing the circuit.
When timer turns ON, it closes circuit between terminals 3 and 4.
So the Hot is closed.
Neutral is not closed, it is open at all times.
EH10 is SPST timer ... One single pole is opened-and-closed (SP), and timer completes action with a single throw (ST)
Nov 24, 2010 | Intermatic 7 Day Electronic Timer Eh10...
Intermatic EH10: I can't figure out how to set a schedule of Sun - Thurs, 8am on, 10pm off and Fri & Sat, 8am on, 11pm off. I tried every day of the week 8am on, 10pm off and Fri & Sat 8am on, 11pm...
The EH10 is 120V digital timer.
The timer offers the following days:
-All 7 days
-Monday thru Friday
-Saturday and Sunday
-Each individual day
-Blankday (day skipper)
If I understand your schedule:
You want
Program1 ON at 8am Sunday
Program1 OFF at 10pm Sunday
Program2 ON at 8am Monday thru Friday (with blankday on Friday)
program2 OFF at 10pm Monday thru Friday (with blankday on Friday)
Program3 ON at 8am Friday
Program3 OFF at 11pm Friday
Program4 ON at 8am Saturday
Program4 OFF at 11pm Saturday
I filled in the chart for you.
I left off the display.
I do not have this timer and don't know 100% how the display looks without buying the timer.
If you need more help on a specific step in the manual, add a comment and I will answer.
Nov 07, 2010 | Intermatic 7 Day Electronic Timer Eh10...
Stopped working. no0 p code
1) Can you identify your timer and then re-post your question?
Here is a link to Intermatic >> on left side of page are types of timers. Press + to expand each selection. There are a lot of timers. It sounds like you have electronic timer, and not a mechanical timer.
2) Guessing at solution without knowing exact timer?!?
Could that code mean 'no power'
Have you checked circuit breaker, click it all the way one direction, and then back the other way
Does manual override work? Does manual override turn the load on-and-off?
Have you checked battery?
EH40, EH10, ST01C, EJ500, EI600 each have a battery, but usually the error code is BATT
Sep 30, 2010 | Intermatic Hardware & Accessories
CMT-EH10 CD player does not recognize any disks
try a cleaning if that does not work then if the unit has been dropped laser could have been knocked out of alignment or has reached the end of it's lifetime. You didn't tell me how old the unit was I've had CD players
that only lasted as little as 11 months and the reader go bad. anyway try the cleaning first and if that don't work
I would look for another unit.
Nov 28, 2009 | Televison & Video
How do I install a Intermatic Electronic water heater timer EH40
Here ya go, follow the directions.
http://lib.store.yahoo.net/lib/rewilliams/eh10.pdf
Jul 08, 2009 | Intermatic EH40 - Electronic Water Heater...
AEG L74650 220volt 50hz 7 Kg Capacity Washer-16224 Logo
14 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
