Question about Saws
Thd950ln parts list
Need bearing on front of motor
jumptrout51
  • 3361 Answers
SOURCE: Need parts-----bearings for motor
Yes. Any HVAC supply house has a replacement motor and capacitor.
If you get the original equipment motor it will be quite expensive.
Get a generic/universal replacement.
All you need is horsepower and rpm info.
Posted on May 26, 2009
johnjohn2
  • 5763 Answers
SOURCE: Need a parts list to change front drivers side
you will only need bearing, its a complete unit with bearing seals and hub all together all you do is remove tire,brake caliper, caliper bracket,brake rotor,and remove axle nut, on back of bearing are 3 bolts that hold it in remove and tap out.hope this helps.
Posted on Oct 13, 2009
bettershoote
  • 13 Answers
SOURCE: Hello, I am trying to replace the front bearing on
If you haven't got your answer yet, I can help you, but it seems very late to reply. I have a same model, I take apart it, I see 2 bearings, you probably need puller to get it out.
Posted on Nov 08, 2012
  • 11 Answers
SOURCE: I am looking for a parts diagram for an A.O. Smith pool pump motor SP3220Z1BE.
The motor is made by A.O. Smith in Tippton, OH. You can try calling them, and with any luck you may get a kind soul that can get you a splsh sheild. It is probably not a part you can purchase from a distributor, but that is an option you can also pursue. Good luck.
Posted on Mar 05, 2013
  • 50503 Answers
SOURCE: how do I remove spindle on Milwaukee Router Model 5680?
you may have to pull the fan off the shaft to get to the screws. If this is the case most fans just push on tight so a small bearing puller in close to the fan hub should do the trick
Posted on Oct 29, 2014
Replace bearing on dyson dy-916217-01
I have a bad motor myself. The bearings make loud noises and the wife is on me to fix it. I can only replace the entire motor because the bearings are not available that I am aware of. The motor runs about $50, cheaper than having them fix it. Dyson does not have parts listed on their pages but you can Google the vacuum/parts and find them. Working on a Dyson is like working on an car. You have to take everything apart to get to what you need to replace. Good luck.
Nov 08, 2013 | Dyson DC17 Brushbar Motor Assy 916217-01
Motor burned up on husky thd950ln wet saw
I have the same problem, Changing the blade will not fix the motor.
Mar 15, 2013 | Garden
Jul 15, 2011 | AO Smith 1 hp 3450rpm 48Y Frame 230/460...
Looking for front wheel bearings for the Qlink xf 200, can't seem to find a parts listing for them. Or do you know if there are any other compatable bearing? ie....
Hi Stevescuba26, the bearing will have a number stamped on it, go online and google bearings retail store then your zip code, for more information about your question please visit the website below. Good luck and have a nice day.
QLINK MOTOR ACCESSORIES PARTS XF 200
Jan 12, 2011 | 2008 Qlink XF 200
I have a flotec pump model FP4122-08, motor #C48J2EC11C3, and a recent freeze broke the motor flange where it bolts onto the pump body. I need to replace the motor base flange but My parts list does not...
I believe the part you actually want is the motor endbell that houses the front motor bearing and it in turn allows the motor to be connected to the pump housing. The number you give is the motor model number...I will also need the motor serial number to ensure we quote you the correct version of the endbell you need as there are design changes from time-to-time. Please email than information to me via the contact us part of our website at www.arrowmotor.net. You should be able to purchase the endbell assuming AOSmith still makes it.
John
Jan 03, 2011 | Garden
Kenmore front loading waster. Model: 970-c45062-10. Loud whirring noise during spin. I can't seem to find this model listed anywhere to determine the replacement part I require. I even called Sears part...
You have a bearing problem. The bearings can be removed, there are 2 bearings and 1 rubber seal plug. The tub can be removed from the washer and split into 2 pieces (rear portion and front portion), and the bearings removed using a large hammer and a pipe (put the pipe in the hole so it contacts the bearing and hit the pipe with the hammer, then flip over the tub and do the other bearing - there are videos on You tube). The bearing part number for this washer are TSB 6306-2RS-CTS (smaller bearing) and 6307-2RS-CTS (the larger one). These are sealed bearings, and can be ordered off ebay or a bearing store.
Dec 31, 2010 | Washing Machines
I need to replace the bearings in the drivers side front wheel,but cant find any car shop or garage that stocks daewoo parts anymore? I've had people tell me i can use bearings from astra? Is there any...
gm dealers, motor traders stock genuine parts for these vehicles, im in australia and can get after market also from, repco, sprints, etc...or even go straight to bearing company eg. cbc bearing company, tkn, etc... depending on brand of old bearing. i suggest you try a bearing company out of phone book some have listings for vehicle applications.
Aug 04, 2010 | Daewoo Lanos Cars & Trucks
Ironman Triad motor cover will not come off
To remove the motor cover (#19 from parts list), you have to remove the follow items first:
- Left and right fenders (#20 and #21 from parts list)
- Left and right sideboard covers (#49 and #50 from parts list)
There are 4 screws holding the cover - 2 at the front and 1 on each side. Be careful when you lift the cover, the circuit breaker cable is attached to the cover.
Finally, you may want to reconsider doing that. There is nothing under the cover that requires maintenance. The big *** motor is driving the front tread roller through a belt. The roller has sealed bearings that do not require oil.
Feb 19, 2010 | Ironman Exercise & Fitness
Bearing failure
you have to pull entire tub assy out of mach,removing all hoses,motor,wiring shocks and springs.then you remove all the bolts going around the middle of front and rear tub.the bearings and seals are pressed into the rear tub and are not removable for separate replacement.rear tub and basket have to be replaced together and is quite expensive to buy these parts..good luck
Sep 24, 2008 | Kenmore 44102 Front Load Washer
Saws Logo
46 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
