Question about Samsung LE40R74BDX 40 in. LCD Television
Got a samsung le40r74bd,when i switch on it takes five to ten mins and there is a continual ticking .could this be the power supply board takes 10mins to 30mins to switch on and also a ticking noise
  • 191 Answers
SOURCE: samsung le40r74bd LCD TV
hi is the power still coming on? if yes no need for power . have u put anntenal & change the chanels b4 then to see if sound will come .if ye s its yuor backlight inverter u can also disconet ur inverter plug & power on  the tv & change channels if works change ur inverter if dead change your ad or mainboard .
for replacement , lcd parts .com. will help
Posted on Nov 10, 2008
  • 41 Answers
SOURCE: sound problems
Sounds like there is a bad solder connection inside the set and needs to be looked at by a tech. The Flashing LED usually will be a code for the tech to send him in the right direction as to the problem. Try counting how many times it flashes and call them or manurfacture. hope this helps
Posted on Apr 01, 2009
  • 187 Answers
SOURCE: sound but no picture samsung le40r74bd
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
Cool_dud 09
  • 206 Answers
SOURCE: power supply board
Hai,
Please check on here....you will find it out!
Posted on Aug 23, 2009
SOURCE: Samsung power supply & IP board BN44-00264B &
For anyone else with this problem...I ended up getting a replacement transformer from ebay and swapping it out myself.
You have to remove the back panel of the TV, unplug the board from the harness going to it, unscrew the board (both via the set of screws going directly through the board and the set going through the plastic piece on the opposite side that, as far as I could tell, the board is glued to). This plastic piece (running the length of the board) has receptacles for the backlight bulbs, so be gentle getting it in and out. Don't forget the screw in the middle of the board.
De-soldering was a little tricky. My soldering skills are not great, so maybe it was me. But it certainly seemed to be a little challenging to get it all out. Having so many terminals probably didn't help (a capacitor would have been easier). Eventually though, I did get it out. Soldering in a new one was easy. Be sure to check continuity between the terminals of the new part and other parts of the board using the traces as a guide once you're done.
After that, simply re-install the board and put all hardware back in. Like I said before, be sure you re-engage the receptacles of all the backlight bulbs by pushing down at each notch on that plastic part of the board.
Hope this helps someone else...
Posted on Dec 19, 2011
My samsung tv model number ln40a55op3f 8. havin troubles getting it to turn on...it wont turn on for like five min, then it will just keep turnin itself on and off until we unplug it...you never see...
The tv have a dying power supply board,that the board where the tv power a/c cord plug into it.U have all the tools and the understanding of basic electronic and also can do basic soldering works too?Yes,take all the Philip screws out of the tv backcover,take the tv aparts and now check the tv power supply board carefully for dying and soon to be dead components parts that are call capacitors.These dying and soon to be dead components capacitors parts are alway bulges up or puffing up onto it tops.These capacitors components parts are dying and soon to be dead must be all to be replaced.After u replacing all the defective capacitors components parts.Now the tv power supply board will be fixed and working correctly again and the tv will not have anymore power delaying like about 5 mins. or flashing LED power light indication,require unplug,replug again awhile before it will turn on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 15, 2011 | Samsung LN40A550 LCD TV
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My samsung tv has no picture or sound the blue light at the bottom is flashing and there is a loud clicking noise coming from the tv
take plug out leave it for ten min retry ..if it dont work you req to change x4 pcb boards its not chep £200... i had to do it with mine if your in bristol i can do it if need to .. 07779933829
Feb 23, 2011 | Samsung LN46A650 46 in. LCD HDTV
Samsung SCX-4521F Possibly lost its power? When
If it just make tick sounds, but does not power up and does not do its normal startup, it probally the power supply board on this printer has failed. This printer like most modern electrical appliances has a switching power supply. The ticking sound is the power supply trying to start, but it senses a fault and shuts down and tries to restart.
I had a similar problem with my printer, though it not the same model (CLX-3160) but the same manufacturer Samsung. I took mine appart and found that one of the capacitors on the power supply had failed. It was blown and the top of the capacitor popped open. I am not saying this is your problem but it would be the first thing I would check if you want to get this fixed. Otherwise, look for a new printer.
Hope this helps.
Jun 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
When i turn the power on the tv clicks for up to ten min before the picture comes on. is this fixable?
Yes,very fixables.Ur tv power suppply board have these parts call capacitors.They are dead and gases leakages,not total,but dying.These capacitors they alway bulges up on it top,puff up on it top,these capacitors are dying,that why tv still have power but it take up to ten min. clicking to recieve power to the rest of the tv.The power supply board,that the board where the power a/c cord plug into it.U have basic understanding of electronic's?U have tools,soldering iron,desoldering pump,solders?Take the tv aparts.U just looking,searches all around the power supply board and replaced these dead,dying capacitors that are bulges,puff up on it tops.Replaced these gases leakages capacitors,ur tv will have it power back to normal and work on the first click.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A450 40 in. LCD TV
I have a Samsung LNS3251D 32-Inch LCD HDTV , that after two years of use is going Off/On every ten seconds after the initial turn On. I understand from reading this forum that the Samsung 40 inch LCD has a...
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Apr 15, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung le40r74bd LCD TV
Nov 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LE40R74BDX 40 in. LCD Television Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
