Question about Garmin nuvi 350 GPS Receiver
Garmin 255w won't stay connected on pc - Garmin nuvi 350 GPS Receiver
bunnydawg
  • 5158 Answers
SOURCE: My garmin nuvi 255w frozen...
you will find a reset button on the outer edge that you can press with a pencil or the like... don't press too hold and i believe you hold it for about fifteen seconds
Posted on Jan 15, 2009
Deneenie
  • 73 Answers
SOURCE: forgot password on my garmin 255W
Page 37 of this manual gives some tips:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Basically, if you want to turn the system on, just return to your "Security Location."
If you want to reset the 4-digit code you will need to send your nuvi to Garmin and provide proof of purchase or valid registration.
Posted on Mar 27, 2009
SOURCE: Registration problem on Garmin 255w
cannot register on this site and peed off
Posted on Sep 17, 2009
SOURCE: No connection to PC
I had the same problem. The solution was so simple but I tried everything I could imagine before this: Remove cable from pc and garmin. Now.. the secret...FIRST switch on your garmin and then connect it to the cable and to the usb port of yor pc! That was is for me! So simple really but in every manual I read it said just connect it, it didnt say first switch it on!!
Posted on Jan 17, 2010
fathitkf
  • 1871 Answers
SOURCE: Iwant a users manual for Garmin nuvi 255W
Hello :
Check this link please . If the page came to you blank you need to refresh it by clicking [ F5 ] .
PLEASE RATE !
Posted on Apr 16, 2010
Can't unlock maps on garmin nuvi 255w after update
You can try to power down for hard reset(disconnect battery) and after connect again or reset to factory setting.
Mar 19, 2013 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Have a large socket but not a usb socket how do I update cannot find a lead that looks like it would fit
The USB cable will have a regular size USB connection on one end and the other end will have a micro USB connection. There will be a micro USB connector on the back side of the nuvi 255W.
The correct cable to use is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Sep 19, 2011 | Garmin nuvi 255W GPS Receiver
How to connect my garmin nuvi 255w to a computer
To connect the Garmin 255w you will need a usb cable. If you don't have one that came with it you can check all your other electronic devices like camera, camcorder,mp3 player etc..( my mp3 player usb cable worked fine). Carefully and gently try each one. One you get a usb cable connect it directly to a usb port on your computer and not thru a usb hub. then go over to the Garmin site and register the unit and download Garmin updater to update your unit. I am attaching the Garmin link for you. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 18, 2011 | Garmin nuvi 255W GPS Receiver
I have received the lifetime update card for my Garmin 255W. Now what do I do next? Apparently I need a username & password. Where do I do that?
When you register your satnav at www.garmin.com you select a username and password. If you haven't already done so you'll need to connect your satnav to your pc to register it. If you have and have forgotten the username and password you'll have to contact Garmin Support. Contact details are at http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=451C4302E8469EEE9E7F2C9DABE2DD6D
Jul 24, 2010 | Garmin nuvi 255W GPS Receiver
Not recognized whenGarminnuvi 255W connected by
There are two types of cable one works in the CAR the other on the PC make sure you have to correct one
Apr 27, 2010 | Garmin nuvi 250W GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
