Question about Comdial Impact 8012S Corded Phone
How do I program the Caller ID to display on the screens...phones are from 1994, but I am pretty sure the ability is there, somewhere!
I have a Comdial Impact phone system. I also have "Caller ID" provided by my phone company...question is: How do I program the phones to show the caller #'s on the digital display? Hopefully the phones are capabel since I am paying for it...true? thx Steve
CORDLESSGURU
  • 106 Answers
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
rylee_smith
  • 8619 Answers
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
  • 32 Answers
SOURCE: Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Posted on Jan 21, 2010
SOURCE: I have a Panasonic KX-TCA132E
I have a panasonic KX-TCA132Ehandset, have managed unknowling turned the ringer off and now can't turn it on again, please help?
Posted on Apr 07, 2010
  • 69 Answers
SOURCE: How do I change display name on a Comdial Impact phone.
The Small Office lite is the voicemail system are you trying to change the name on the voicemail or the telephone set. There should be a comdial cabinet hanging on a wall if you look on the right hand side of the cabinet there should be a sticker with a american flag on it this sticker will tell you model
Posted on May 26, 2010
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Hi is there a way I can check caller id on my phone
That is a feature sold by your local telephone company. It cost a few bucks to have it added to your telephone line, then your phone has to have the ability to display caller ID. if your phone does not have that ability, then you can buy a display device that plugs into your line and displays it, It will only display those callers that do not block their lines from being IDed.
Jan 11, 2011 | Avaya Definity 6408D Corded Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. www.dyns-tech.us We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
It does not display the area code on the caller ID
Somewhere, you told it your area code. Take that part out or put a different one in and it will show 10 digits.
Carl
May 19, 2009 | Uniden Cordless Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
Caller ID
Since it appears by default, I'm guessing that the phone is not ringing. It has to ring to display CID. You need to make sure that it is part of an ICD group with Immediate ring.
Carl
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
Comdial Impact 8012S Corded Phone Logo
350 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
