Question about Tablets & eReaders
My pendo pad 7" will not load past the android screen now after I changed one of the display options in settings (it had something to do with rendering...) I was trying to improve the performance and
Pendo Pad 7" 4gb storage 4.2 android os, jellybean model: PNDPP41DG7BLK
3 Suggested Answers
SOURCE: how to unlock pendo pad
Unlocking your Pendo Pad is easy, if you forgot your pattern code. Just keep putting in wrong patterns, you need to do this at least 20 times, sometimes you will be unable to continue for a few seconds after 5, 10, 15 attempts,but just wait it out & keep going. Eventually it will ask you to enter your Google email & password & Bingo, you`re back in!!
Posted on Dec 01, 2011
guerrero_ros
  • 113 Answers
SOURCE: how to reset pendo pad
Go to settings and scroll till you find reboot your device to factory settings. Or "backup and reset" Under "Accounts" in your settings. Then click on "backup and reset." Every tablet and cell are somewhat different. Be sure to read your manual, very easy to do when you are familiar with your device.
Posted on May 13, 2014
My pendo pad 7 doesnot start , only "aneroid" logo appears on the screen, what to do for it to start.
I am not exactly sure what the issue would be with this. I would contact the support site for the pendo product and see what they have to say. You may need to reload the android OS to make this work.
Jun 05, 2016 | Tablets & eReaders
I have a pendo pad 7 inch am it wont power on.
If it won't power on there is not much you can do. Try to check the output of the recharger; if it's ok so take your device back to the store where you bought it and if it's on warranty they should take care of it, else they should provide an authorized technical service to do the proper diagnosis and evaluate the cost of repairing it. You should decide if it can and is worth to be repaired.
Aug 06, 2015 | Tablets & eReaders
My son's pendo pad 7 won't turn on at all. I've currently got it on the charger but unsure if it's even charging :/ how can I tell if it's actually charging? Please help.
Unfortunately if there are no lights on the charger itself there is no way to tell. If you are just getting a blank screen and no indication that the LEDs behind the screen are lighting up or anything is happening at all, you may have a mechanical hardware failure. This could have been caused from water, a drop or some other hazard like extreme heat.
Your best bet is to find a local PC repair shop that services tablets or contact the manufacture and arrange a service ticket.
Apr 14, 2015 | Tablets & eReaders
Chromo tablet
You can't put letters on the number pad but you can change your password to be made up of letters. You do this by going to settings, security, then at the top of the page it will say number pad or something, you click on that, then follow the instructions.
Jul 20, 2014 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
Why does my 7" android series only display android on the screen when turned on ,does this need rebooting and if so how do i go about it?
So it only says android and never loads to the point you see the screens you are used to?
Sounds like a failed update or something. Look up and perform a factory reset. It's usually a button holding down combo but I don't know what yours would be.
Jul 20, 2014 | Acer Iconia B Series B1-710 with WiFi 7"...
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Pendo pad won't work
Something like this happened to my ipad. We had to do something with hooking it up to the computer and going on iTunes and everything and couldn't figure it out so we had to take it in. You can probably take it in to the company who made it and talk to them. ;) :)
Jun 16, 2013 | Tablets & eReaders
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
Pendo pad tpc7slv to unlock sign but wifi not working how can i connect
i cannot open my pendo pad tpc7slv because it was locked and i dont know how to open it.how to reset it without wifi connection
Nov 29, 2012 | Tablets & eReaders
Tablets & eReaders Logo
102 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
