Question about LG Washing Machines
Wm0642hw The screw in the back of the machine that holds a silver plate in place that makes the washer spin keeps coming loose
    Sergeant:
  • LG Expert
  • 302 Answers
Try a product called Loktite it will stop your screw from coming out
Posted on Dec 29, 2013
Master_Tech
  • 770 Answers
SOURCE: Baffle came loose from drum...how do I
there are 3 Tork screrws on the back panel that will allow for you to slide the top back and get access to the top of the drum
Posted on Jun 01, 2008
cbgarner
  • 138 Answers
SOURCE: agitator keeps coming loose and off on the daewoo "dwf8094r"
locktite would be an excellent solution.
Posted on May 13, 2009
localwonder
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
  • 4088 Answers
SOURCE: Centrex top loader washing machine
The part that the screw holds is turning independently of the screw. Remove it and inspect for torn splines or other motion locking device. Repair or replace the part using Loctite on the screw threads.
Posted on Sep 14, 2009
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
Lg waveforce top load washer that is around 3yrs old. The agitator plate hold down screw (under the chrome cap) keeps coming loose and at the end of the wash the plate is up with clothes under it.
Remove the screw and look underneath the agitator, GE machines have a correct way to put them back so the agitator sits at the bottom of the machine with virtually no gap. Tighten the screw hard. Perhaps you lost a locking washer at some stage?
We moved to front loaders.
Oct 24, 2015 | LG Washing Machines
I purchased a fashion maker in second hand basis.now when i stitch the cloth is not moving backward and it is stitching in only one place.what shall i do to make the cloth move.
Take off the foot and remove the thread from your needle.
Turn the hand wheel towards you, and watch the plate the needle goes through.
The feed dogs should come up through the needle plate, move towards the back of the machine, then go back down through the plate.
If this IS happening, then your foot pressure might be too light or your thread tension (top and or bottom) is too tight.
If this is not happening, the most common problem is the screws holding the feed dog on are loose. Remove the needle plate, locate the 1 or 2 screws holding the feed dogs on and tighten them.
If the screws are not loose, I will need more information.
Jan 23, 2014 | Sewing Machines
Not Spinning LG WM2301HR
Steve R is right except that if the splines in the rotor are stripped you will have to buy a new rotor or the bolt will just continue to lossen itself up. The rotor is $64.33 online. Still a ten minute fix, after you wait a week for part delivery.
Jan 11, 2012 | LG WM-2077C Front Load Washer
My top loader whirlpool washing machine (model SM8280869, I think) will not drain or spin. I have checked the inlet and drain hoses, they are not clogged or kinked, and the drain hose is about 12? above...
The switch needs to be secure and make sure that the wiring did not come off the back of the switch. On the back of the washer there should be two or three screws holding on metal brackets that keep the top and the rest of the washer together at the seam. Once removed you should be able to lift the top up and out enough to inspect, keep in mind that the rest of the wiring for the dials will be still connected. Hope this helps and dont forget to unplug first
Jan 18, 2011 | Washing Machines
How do I replace the switch that makes the machine spin on model # 110.2690191, Stock # 26901. It has fallen loose from the machine.
With a philips screwdriver remove the 4 front control panel screws; (2 under each corner;) (you may need to remove the control panel plastic side covers first.)
they just snap off.
Remove the two screws holding the back panel to the yellow plastic clips
on the back of the control panel.
Slide the control panel to the front of the washer about 1 inch; releasing it from the top of the washer;
set the control panel aside.
You should now see two large gold-colored metal clips (make sure you know how they look in place) remove the clips by sliding the screwdriver under them and pulling up;
(be careful they can fly at you.)
tip body of the washer forward it will now come away from the tub frame.
You can now replace the lid switch; reverse these instructions to reassemble your washer.
Now you can replace the lid switch; reverse the instructions to reassemble.
Aug 03, 2010 | Kenmore 24032\24036 Top Load Washer
Apr 07, 2010 | LG Washing Machines
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG Washer WM0642HW: Not enough water
Turn clockwise the water level sensor set screw a half turn "clockwise" under the top of the machine lid.This is the only way to rid yourself of the WICK WATER RUB WASH METHOD that is just terrible. Especially with a full load ! BELIEVE ME. I really wonder if consumers who have the WM0642HW earlier produced version with the nozzle spray system in the top of the door seal are having these troubles?. Mine is a 2009 verson of the WM0642HW, No Forced Water Recirculation. ( Discontinued) and how it was preset for fill at the factory made it perform terribly. Only after i adjusted the water level sensor does it perform well the first time around. Have yet had to rewash anything since the adjustment i made for the fill level. Good Luck.
Nov 09, 2008 | Washing Machines
Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Oct 04, 2008 | Bernina Artista 180
Washing Machines Logo
81 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
