Question about Singer Sewing Machines
Material is puckering.i was hemming pants ,that went good;so i tried working with a very light material.threads are nor releasing, i guess, as the material is pulling together as i sew, its all puckered.
    Problem Solver:
  • 9 Answers
You should always use needles that are the right size and sharpness for different fabrics. any fabric store can help you with this. according to your machine the smaller the # on the needle the finer teh fabric it will sew. also using the right weight of thread is important...light weight thread for light weight fabric and heavier for thicker fabrics
Posted on May 23, 2009
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
Need help with tension as thr stiches are puckering.
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
How to Prevent Your Sewing Machine from Puckering Fabric Howcast
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjcuq2nkIPMAhXlxIMKHVgUAqUQFgg1MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Stitching is puckering on lightweight fabric SEWING IN GENERAL
All About Needles
Apr 10, 2016 | Sewing Machines
I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Jun 02, 2011 | Bernina Activa 140
Cant let any type of material go through its self or it puckers tryed every combination of tension model xl3520 brother
If your material is puckering then the thread tension (Top and Bottom) are way too tight. Loosen both.
Good Luck!
Chris
glfi.com
Jan 21, 2011 | Brother Sewing Machines
I am trying to hem a pair of Lulu Lemon yoga pants and the material keeps getting caught (pulled down into the needle guide.) I am using a double needle and in "B" # 73. That design actually allows the...
Most likely the pants are a knit or stretchy fabric and you should be using a ballpoint needle especially for knits. Try poking the needles through your fabric and pull them back out just to see if there's a burr on one of them. If not, you can use them if you can't get the ballpoint ones. If the fabric is knit and it keeps getting caught, try putting a stabilizer under the fabric to get it to sew smoothly. You can try a light tearaway from Joanne Fabrics. If you can't get to a store, try waxed paper, tissue paper, an old pattern or anything that you have that can be torn away after you stitch. You only need a strip on the bottom of the hem. If the pattern is intricate and the paper sticks after the tearaway process, you can just dampen the paper so it will fall off. Hope this solves your problem.
Sep 10, 2010 | Kenmore 19233 Computerized Sewing Machine
Placing material for rolled hem
Usually what is done as far as I do it, is to sew a straight stitch at 45 degrees to the corner that you are going to hem and use the threads to guide the material into the hemmer foot. Once the presser foot is lowered you hold onto these threads to guide the material in a straight line while at the same time holding your fabric slightly elevated in your right hand so that you allow the hemmer to be just full at all times. After you complete your hem remove your 45 degree helper threads. Your fabric must also be cut very straight or you will not get good results with the hemmer. This foot takes practice to master...once you know how to use it, you will never look back! There are other methods to using this foot that other people prefer, but for me this one works the best.
Aug 25, 2009 | Husqvarna Sewing Machines
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
Puckering material
You may need to utilize backing to correct the puckering, and/or if possible, also sew on the bias. I do not have enough information to interpret the origin/cause of the "noise". Please click on the URL below for helpful information in correcting typical stitching and machine woes....good luck my friend: http://www.fixya.com/support/t162553-underthread_going_crazy
Jul 26, 2007 | Toyota SE-06 Mechanical Sewing Machine
Sewing Machines Logo
172 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
