Question about Cameras
TV remote burns through batteries
Remote burn out batteries after a few hours and requires lithium batteries.
Thank you for the reply. In investigating the Ilio Plasma TV, I found if it worked HOORAY. It does. Further investigation revealed resetting the sensor may fix the burned out remote. We have the TV up and out of the way so when we do get it operating again soon, we will try the sensor reset and a new set of batteries.
Posted on Dec 30, 2013
Hisense TV, remote keeps using up my batteries, only last a week or two.
seen this battery issue reported online before with these remotes
depending on age and model of that TV
you can buy new original ones
dont buy universal types for a hisense
is it the original remote ?
what brand of batteries
lithium energizer?
info
rechargeable batteries never fully charge up
only two needed
size is AAA or AA
Oct 23, 2016 | Cars & Trucks
Rmote got wet, aand won't turn on?
  • Remove the batteries,
  • Keep the remote in hot place, careful to not to burn your remote
  • Or dry it using a blower, heir drier or something
  • After few hours try again with batteries
  • It will work
If not you need assistance. Take it to a Tech guy.
Jun 21, 2015 | Cars & Trucks
How do I remove burn images from a Sanyo TV?
I am assuming this is a Plasma TV? If so, Once an image is burned into the screen,there is now way to remove it. There are some ways to remove temp burn-in images like playing a white screen,and a screen wipe program. But,this only helps if you see a burn-in after watching the same image for a few hours. If the image has been played over a long period of time. "Like a store demo, security camera, ESPN like at a bar" There is no repair for this. And the screen will need to be replaced,and the cost of the replacement is sometimes more than buying a new TV. Sorry to have to give you this bad news. If you bought a extended war.? It may cover the burn-in. Some warranties
will cover that. It is worth a try.
May 04, 2014 | Sanyo Televison & Video
Hello i have a 32 inch norcent vion LT-3290 Flat Screen LCD TV and after playing video games for a few hours some of the pictures that are constantly in the same place the whole time burn in the screen and...
put tv on blue screen and leave it on blue screen for a few hours it should clean up the burn in abit. on some screens they don't like to have the same screen on and no movement some tvs have a built in screen adjuster it flickers a bit so much that you dont even see it but its to stop this from happening to the screen.
Jul 14, 2017 | Norcent Technologies LT3222 LT-3222 LT3225...
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    How long does it take to charge the battery to a full charge...thanks,judy....on a presario V2000
    usually 8 hours is what is suggested when you get a new battery. i like to burn down the power on the battery completely till it turns the unit off, then let charge for 24 hours just to reset the battery correctly.
    Jul 19, 2009 | HP Compaq Presario V2000 Notebook
    DISH Remote burning through batteries!!
    most likely there is a button on the remote that is stuck on. try moving all the buttons to see if they "feel" stuck. if not then take the remote apart and clean the contact pad bottoms and the surface of the board with rubbing alchohol. good luck!
    Feb 15, 2009 | DISH Network IR Remote Control
    My Samsung Plasma just got burned in!
    I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
    Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
    Cameras Logo
    26 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
