Question about New Bright Ford F150 RC Truck
New Bright FordF150 r/c truck won't go backward or forward although wheels can be turned right and left. It has 6.4 volt lithium battery which has been charged.
3 Suggested Answers
SOURCE: Forward does not work - 19.2 V New Bright Buggy
It is a problem with the circuit board. To my knowledge New Bright does not have anywhere that you can order the board.
Posted on Nov 30, 2009
rickyrt441
  • 4399 Answers
SOURCE: I have a 19.2 volt "New Bright F-150" and the
Your best best is going to E-Bay.
Posted on Feb 18, 2011
Honda passport 1999 stuck in 4 wheel drive
Possible bad front diff actuator.
Jan 14, 2015 | 1999 Honda Passport
Horn intermittently blowing
your horn is shorting out on your steering colum just trace wires back from steering wheel and look for were its been uncovered
Nov 27, 2013 | 2000 Dodge Stratus
The car won't go forward or backward
Lift up all the wheels one by one, rotate each wheel and check which wheel resists to rotate. Disassemble the jammed wheel and carefully examine to see why is it so.
Grease the caliper pins, free up the pistons and reset the brake components.
Dec 03, 2012 | 2001 Toyota Echo
Left wheel has lost 75% forward/backward power.
fluid level but if its that new it should have a warr
Apr 26, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
I need to find a 19.2 V battery and remote for my Hummer H2 Mud Slinger. Where do I look?
A 1:14 Mudslinger requires a 6 Volt battery. Not a 19.2 Volt. Now when you go purchase this battery make sure it says 6 Volt not a 6 Cell. Here is the style battery you need. http://www.all-battery.com/6vrccarreceiverbattery.aspx
Starting from the top left you can choose the first 5 depending on the shape of the one you have for the RC and the mAh you want. The term mAh indicaters milliamp hours. Basically how long the battery will last. More bang for your buck basically. But they cost more too. They will all function the same. But the ones with less mAh will run out of juice sooner and have to be charged. All these connect the same way from the same style connector. So don't worry about that. Hope this helps.
Regards, Tony
Mar 24, 2011 | New Bright Bright 114 Scale Mud Slinger -...
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
1997 Mercury villager left headlight doesn't work.
go here. we can help you. Also, did you check the headlamp relay in the box under the hood? One relay is in box in front of battery, other is in narrow box along passenger side fender under the hood. swap left & rt headlamp relays to see if it changes.
http://groups.yahoo.com/group/villagerquest/
Jul 13, 2009 | 1995 Mercury Villager
New Bright Ford F150 RC Truck Logo
73 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
