Question about Bodum Antigua 5670/5671 Electric Burr Grinder
Plastic container that catches the coffe grounds is broken
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
I have a Jura Impressa C5. My drip tray mechanism is broken because I pulled out the tray while it was still operating, and a piece of plastic of about 7.5cm x 17 cm (3 in x 7 in approx) came off and...
This is the used grounds blade that makes room in the used grounds container. This is fixed to the brewing unit, and can not be reassembled without opening the machine. If you make sure to check your grounds container often, you really don`t need to put this blade back. Just make sure that the container doesn`t overfill.
Apr 27, 2011 | Jura Capresso IMPRESSA F60
None of the gauges work?
Suggest that it is a bad ground.
Your instrument dash is made of plastic. There is a large plastic strip on the backside of it, that contains Thin, Very, small copper strips. These copper strips conduct electricity to the gauges, and also a ground source.
There is a flat cable, or wire, (Or more than one), that connects from that plastic strip, to the metal body of your Jeep. This is the ground source to that plastic strip. If it has a loose connection, (loose bolt), corrosion, or rust at the connection to the body, or is broken, you will have lost your instrument panel's ground.
Also there should be 2 flat braided cables leading from the firewall, (Hood open. Under the windshield), to the engine. These need to be connected, and there should be 2 of them, not 1.
Aug 02, 2009 | 1989 Jeep Wrangler
Problem with Saeco royal digital plus
Try replacing the O ring in the brew unit
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Bodum Antigua 5670/5671 Electric Burr Grinder Logo
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
