Question about Dell Dimension 8250 PC Desktop
Dell Dimension 8250 PC Desktop - Does the PC 32 bit or 64 bit processing
melnavz
  • 1226 Answers
SOURCE: Dell Dimension 8250 Memory Question
Hello woid!
Better too late than never but better never late!
I would like to answer your question about you computer! Your computer can maximize memory upto 2 GB depending on the type of memory:
In PC800 memory(non-ECC)- can support upto 2gb
In PC1066 RDRAM (non-ECC) - can support upto 1.5GB
for more information about your computer you can see it here:
http://support.dell.com/support/edocs/systems/dim8250/specs.htm
Hope this answer your question.
Posted on Dec 20, 2007
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 3940 Answers
SOURCE: full system restore without disk for dell
The Dimension 8250 was not equipped by Dell with an automated re-image process. If you want a clean installation of Windows, it will require a manual installation from the Dell Windows Media, followed by installing the drivers from either the resource CD or internat download. Once completed, then reinstall all applications.
Posted on Apr 12, 2009
  • 3940 Answers
SOURCE: IE 32-bit browser need to run on my 64-bit browser
The Internet Explorer shortcut in the Quick Launch toolbar and in the Start menu of Vista x64 will run the 32-bit version of Internet Explorer by default. Why run the 32-bit version if IE on the 64-bit version of Vista?
There are actually two shortcuts for Internet Explorer in the "All Programs" menu. Why two and what's the difference?
Here's the title of each and the exe's they run:
Internet Explorer
"C:\Program Files (x86)\Internet Explorer\iexplore.exe"
Internet Explorer (64-bit)
"C:\Program Files\Internet Explorer\iexplore.exe"
The first one runs IE from the "Program Files (x86)" folder, this is the 32-bit version. The second one is the 64-bit version.
Reference:
http://pietschsoft.com/post/2006/12/03/Vista-Experience-Update-Windows-Vista-x64-runs-32-bit-Internet-Explorer-by-Default.aspx
Posted on May 01, 2009
preachw996
  • 1179 Answers
SOURCE: I have a dell dimension 8250. I lost my sound, but
Either your soundcard driver has gotten corrupted or your soundcard has died. You can find both the driver & info on what card you have at www.dell.com. Click on the support link and you can either input your Dell Service Tag & get exact system info, or you can look it up using the system model #. The driver will be available for download. Try reinstalling an updated driver first. If that still doesn't work check your device manager to see if a soundcard is listed. If it is not then more than likely your card has died and will need to be replaced. Hope this helps.
Posted on Jul 11, 2009
I wish to upgrade my PC with windows 7
Depends on your Hardware.... if it is a slightly Older Computer then chances are it is a 32 Bit.... but if it is one to just a couple of years old... it COULD be a 64 Bit......
Regardless of if 32 or 54 Bit the Computer WILL run on 32 Bit Win 7.
and again regardless of 32 or 64 bit,.... 32 Bit Software SHOULD run on it without problems, but you may have to set it to "Compatibility Mode"
Good Luck
Jun 03, 2014 | Dell Dimension E310 PC Desktop
Dell dimension maximum cpu upgrade
http://www.cpu-upgrade.com/index.html
You will need to type motherboard name ID and the cpu ID
Significance
Upgrading to more modern operating systems depends on the type of processor in the computer.
One of the main differences between the two systems is that a 32-bit operation requires either a 32-bit or 64-bit processor, while a 64-bit version must have at least a 64-bit processor.
Identification
The operating system will register different on each computer that is running the platform. When a user clicks on the Start button, they can go to the Control Panel, followed by the System and Maintenance tab and click on System.
This will show whether the computer is running a 32-bit or 64-bit operating system
Hope this helps.
Nov 29, 2012 | Dell Dimension 3100 PC Desktop
1. Can Dell Dimension 9100 work with 2x2gb ram? 2. I am trying to install Windows 7 on a refurbished Dell Dimension 9100. It has 2x2gb ram, 1 TB Hard Drive and I have Windows 7 32 and 64 bits + Palit...
Here is a link for upgrading to Win 7: http://en.community.dell.com/support-forums/desktop/f/3514/t/19356108.aspx
If you can't boot form the CD/DVD you have a problem with your CD/DVD drive. If you can enter the BOIS (setup menu) then your computer is working, just waiting for a device to boot from.
Mar 20, 2011 | Dell Dimension 9100 PC Desktop
Is this a 32 bit or 64 bit system
Open the start menu, and right click on 'My Computer' or 'Computer' depending on the version of Windows you have. Click 'Properties'. A new window will open, displaying information about your system. Look near the top of the window. It will display your version of Windows, as well as if it is 32 or 64 bits.
Mar 10, 2011 | Dell Dimension 8400 PC Desktop
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
I would like to buy a new dell but not sure how much memory i would need. I don't recall how much memory is in my previous dell. It is a dell dimension xp. Would you please let me know how many GB there...
With any new computer you should get 4 GB of memory, the more the better. There are two version of Windows you can get 32 or 64 bit. The 32 bit version of Windows has a 4 GB maximum on the memory, the 64 bit versions go much higher depending on the version you get. 4 GB will give most people more than enough to do what they need. To see how much memory you currently have just Right-Click on the My Computer icon and select properties. In the window that comes up you will see the memory you currently have.
Jan 30, 2010 | Dell Dimension 3000 PC Desktop
I try clean install to 64 bit win 7 from xp media center (32 bit), computer screen freeze at ''starting windows''. Can not install...
Are you sure your computer supports 64-bit processing? And if it does, try booting the Windows 7 disk and try to repair Windows following the steps. Hope it helps!
Nov 06, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Full system restore without disk for dell dimension 8250
Apr 12, 2009 | Dell Dimension 8250 PC Desktop
Vista 32 Bit verses 64 Bit
Before you jump in and upgrade make sure your computer system is 64 bit ready otherwise it wont work at all....upgrading memory is never a bad thing will actually speed up things from running and will have a better response time....windows 7 does not require 64 bit but it desired if possible....
Apr 11, 2009 | Dell Dimension 3100 PC Desktop
Unsure of what type of PCI expansion slot in dimension 2400
8 and 16 bit PCI slots haven't been used in years so your slots would be 32 bit unless your PC is extremely old. That card will work fine.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 8250 PC Desktop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
