Question about Pyle Pha25 3.5mm / 1/8 2 Channel 300 Watt Stereo Audio Amplifier Amp
How do you hook up a pyle pha25 amp - Pyle Pha25 3.5mm / 1/8 2 Channel 300 Watt Stereo Audio Amplifier Amp
How do I hook up?
First read the instructions they contain some amazing information.
Jun 12, 2014 | Pyle PTA1000 Amplifier
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
I am trying to hook up 3 kicker subs with a pyle 1400 watt amp in my 98 Eddie Bauer explorer and i am not sure how to do it because it has the stock amp in the back passenger quarter panel
First off, you won't be able to do this with a Pyle amp. Pyle amps are only 2 ohm stable (at best). When you do a 3 sub set up (assuming that they are all single 4 ohm voice coil), you will get either a 1.33 ohm load (way to low for that amp and will fry it quick), or you will get 12 ohms (hardly worth hooking up because of the lack of power).
Now say you have dual 4 ohm subs. You will still have the same problem going even lower than the 1.33 ohm or 6 ohms.
My recommendation is either do a 2 sub set up or get a better amp.
I know it's not what you want to hear, but it's true.
Aug 29, 2011 | Car Audio & Video
I have a 10" pyle
+ to + but if your amp shuts off and turns on switch it to + to -
May 05, 2011 | Pyle Car Audio & Video
My pyle dvd player has picture but no sound it plays through the subs but not the speakers
What Kind of Vehicle Do you Drive... It is Possible that you have a Factory Amp installed that runs all the stock speakers in the vehicle(LF, RF, LR, RR.). You would have locate the Amp remote wire for the stock amp and hook it up to the remote amp wire on your deck.
Jan 10, 2011 | Pyle PLD7MU Car DVD Player
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Pyle Pha25 3.5mm / 1/8 2 Channel 300 Watt Stereo Audio Amplifier Amp Logo
57 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
