Question about DeLonghi Heating & Cooling
Delonghi type 3107
Power lights on, but won't heat. Is there a thetmostat, or reset?
2 Suggested Answers
  • 41955 Answers
SOURCE: Delonghi TYPE 3107 with 816F next to UL label iS there a recall?
Google DeLonghi heater recall to find out.
Posted on Nov 19, 2016
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
The on/off toggle switch on the side of my model no. 3107 has fallen off. I would like to replace it.
I was able to fix mine - it was a failure of the pivot points, I drilled out where they'd been, put the switch back together, and inserted a brad (tiny nail) for a new pivot. Works great!
Nov 27, 2010 | DeLonghi Heating & Cooling
Hi. I have a DeLonghi 3107 radiator-type heater, g...
Personally I would throw it away. those radiator type heaters were OIL filled when new ,not water filled
May 20, 2010 | Heating & Cooling
How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
I have a carrier heatpump model 38Q130300 when I turn the thetmostat to run the fan the heat comes on and stays on until I turn the fan off. Any Ideas. Thanks Doug
suggest starting with thermostat replacement only because it sounds as if the fan/heating control has constant power.
good luck
Dave
Jul 16, 2009 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
