Question about Acer Aspire 5735 Notebook
Tray App msi repair
Resolve Tray App msi
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
When you get the error for missing trayapp.Download full feature software and drivers from hp.com. After extracting the downloaded file. Go to your my document's folder. Click tools, go to folder options and make sure to enable "show hidden folders". On the missing trayapp error message, click browse, go to my computer, go to disk drive C:, go to user and document settings, open the folder that has your login name, look for application data > local > temp > open a folder named 7z345 or any folder that has 7z for a file name.. open setup > open trayapp > then click trayapp.msi and click open.. a long process but that should solve your missing trayapp problem.. if you need help, i suggest you call hp
Posted on May 22, 2014
My MSI GT660 Dvd will not open or eject
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 18, 2013 | MSI GT660 Series CD 8X DVD RW DL Burner...
Tray app missing
What Tray app? What OS? In the Tray Notification Area? Open Task Manager, find "explorer.exe, click on it and End Process, all you desktop will disapear, click on File in the top left of Task Manager, open New Task (Run...), in Create New Task, type exprorer and OK. Your Tray Notification Area will reset.
Jan 31, 2013 | HP Pavilion Computers & Internet
What is mean PSSWCORE
PSSWCORE.msi messages are related to printer software. You may want to uninstall and reinstall your printer software, which should resolve that.
If not try this Microsoft tool to resolve MSI issues:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
(MSI is a Microsoft Installer file). The fixit above can help resolve that.
Feb 14, 2012 | Office Equipment & Supplies
I HAVE UPGRADED MY DESK TOP FROM WIN VISTA TO WIN 7 HOME BASIC. I UPLOADED THE DRIVER FOR HP OJ 5610 FOR WIN 7. IT IS SUCCESSFULY UPLOADED BUT I AM NOT ABLE TO USE THE HP SOLUTION FUNCTIONALITY AS IT SHOWS...
SOLUTION:
Here are the steps to resolve this issue (was tested):
Disconnect printer USB from the computer.
Inside the HP software/driver cd, go to "util" directory > "ccc" directory.
In here run Uninstaller_L1 through L4 in order.
Check Add/Remove programs inside Control Panel for additional HP programs that weren't removed and remove them.
Delete HP and/or Hewlett-Packard directory inside Program Files.
Goto Program Files > Common Files and delete HP and/or Hewlett-Packard directory there as well.
Go to Start>Run and type "temp". inside this folder delete all files.
Go to Start>Run and type "%temp%". inside this folder delete all files.
For additional cleanup when using Vista, you can download Cleanup Utility and search for additional HP components that weren't removed. Here's a link for the program: http://support.microsoft.com/kb/290301
Restart and reinstall the driver using the CD or web driver.
The issue should now be resolved.
Sep 13, 2010 | Computers & Internet
I keep getting a message saying tray app installation incomplete please insert cd. problem is I don't know which program did not completely install and this message won't go away
There are 3 step to repair trayapp.msi error
If you got trayapp.msi error then there is a 94% chance that your computer has registry problems. To repair trayapp.msi error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair trayapp.msi error.
Here are the url of Perfect Optimizer:http://www.fixerrorsafe.com/ttfix-trayap
Nov 13, 2009 | HP Pavilion dv9000z Notebook
TrayApp keeps trying to install when computer is started
If you have downloaded the software from web and if you have installed it then
just click on run and then Type %temp% and hit enter
look for a folder name starting with 7z
open that folder
go to setup folder
go to trayapp folder
and then repair the trayapp.msi file by doing a right click on it and i am sure this will do
Nov 01, 2009 | HP Office Equipment & Supplies
MSI.dot4wrp01
Fatal Error during Installation - MSI.dot4wrp01
Try this link. I was able to resolve this with this solution.
Mar 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
CD tray doesn't open
ok there is a small hole below the tray, use a small paper clip
wire to push in that whole, push and the tray should come out.
if that doesnt work take cd player out, push plastic clips on side
and top at front , front plate should come off .
where small whole was in front look behind plate you will see a small little metal arm push on that
should be able to clear cd player then .
Jan 27, 2008 | MSI (MS-P8148-050) (MSP8148050) CD-ROM...
Acer Aspire 5735 Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
