Question about Samsung RF197ACWP 17.8 Cu. Ft. Counter Depth French Door Refrigerator
Door flap hinge broken and won't allow the left door to close without manually guiding flap into slot ontop of fridge to be able to close both french doors.
2 Suggested Answers
brianmcevoy4
  • 41 Answers
SOURCE: Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Posted on Jan 22, 2015
The left door isn't closing with the magnet. (It isn't a rubber hinge/strip problem) It is the bumper inside at the top which isn't gliding over the stop on the door side
Try cleaning both surfaces with a bit of dish detergent on a damp sponge, to remove any sticky stuff, then apply a burst of silicone spray. That's what worked on our fridge when the freezer door became balky.
Feb 22, 2016 | Samsung RFG237AARS 23 Cu. Ft. Counter...
French doors don't close without a push.
Take the gaskets out again. warm them in very hot water for 5 mins before refitting them on the opposite door. Then adjust the hinges to check. Also make sure the shelves are pushed right the way in, not keeping the door open.
Dec 05, 2015 | Liebherr HCS2062
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Plastic ice shoot is broken. How do I remove the old one?
The ice shoot just snapps of of the arm . Pt # 2180224 . Once off , you will see how to snap back on . Usually an ice guide ( ice shoot ) will not allow the flap to close if shoot is broken .
Jul 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Samsung RF197ACWP 17.8 Cu. Ft. Counter Depth French Door Refrigerator Logo
46 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
