Question about Toshiba 46XV640U 46 in TV
Keeps taling longer for tv to start
Toshiba 46xv640u the tv kept taking longer and longer to start... the power would come on but no picture. Once I had a picture, I just left it on for a few months so I could watch tv with out waiting for a long time for it to start up. One day, the power went out and the tv will not started again.
    Top Expert:
  • Toshiba Master
  • 44,926 Answers
Probable power supply decline to failure.
Posted on Dec 28, 2013
Testimonial: "replaced power supply and still no picture... tv turns on, but still no picture."
SOURCE: Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Posted on Oct 10, 2007
  • 2336 Answers
SOURCE: Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Posted on Apr 28, 2008
SOURCE: Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Posted on Feb 17, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: No picture
You have a bad Y sustain or bad Z sustain! End of story! Please feel free to give me a call if you would like more info!
I'll help u fix your TV!
Ask for Dave @ 1-503-432-9904 or message me @ pleasefixitdave@yahoo.com
Posted on Sep 11, 2009
Can I watch netflex movies on my Toshiba 46xv640u tv?
I just downloaded the manual from Toshiba and did a search for Netflix and nothing came up. When I googled your model I saw other people complaining that the TV didn't come with Netflix built in. You can download the manual here: 46xv640u om pdf
Jan 28, 2015 | Toshiba 46XV640U 46 in TV
My toshiba 46xv640u goes through the initial setup every time after turning it off and turning it on later.
Most newer LCD, LED, or Plasma models "flash" the setup into non-volatile memory devices so this is not normal. If you are requested to "save" the configuration and don't or don't know how, maybe this would happen. Even power outages should not cause what you are seeing unless the configuration is somehow not be retained when the power is removed or by chance you are using a power strip to turn it off when it needs constant power to retain the settings.
Dec 01, 2014 | Toshiba 46XV640U 46-inch Hdmi Lcd Tv 16 9...
My 36'' Toshiba televisions picture keeps going fuzzy then if you turn it off and on the picture comes back on. Also when watching movies we lose the picture but hear the sound. Once again if I turn off...
I would start with the Tcon but the main would do this as well, along with the power board...test the voltages coming from the ps board when its giving issues and see if they are ok, if they are try the tcon board
Dec 11, 2017 | Toshiba 36A40 36" TV
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My parents lost their manual for their new Toshiba Tv. Model # 46XV640U. Where can I get one.
on the web at toshiba.com customer care just download it . it is free
Dec 02, 2009 | Televison & Video
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba TV picture has shifted high
if it cannot be adjusted then there is a problem in tv. your problem is in vertical output circuit Can this be corrected easily ? yes or do I need to start looking for a new TV? I love this one and would like to keep it a while longer. not to look for new tv.you will keep it for longer that has a picture that recently shifted upward and now cuts off about 1 inch of the top of the picture. Otherwise it functions properly. your problem is in vertical output circuit please check 1loose contact in vertical output section 2 capacitor defective in v/output. it is a common problem. it is a not a major problem. if you are not tech person get it done by skilled tech. hope this will help.
Sep 30, 2007 | Toshiba 32A33 32" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 46XV640U 46 in TV Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
