Question about Capresso Jura-Giga 5 Professional Home Coffee Machine - 13623
Coffee spouts are clogged
Hot water and milk spouts are functional, the machine has been cleaned. No coffee flows from the spouts, I have tried to manually unclog from the exit with a paper clip
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Dismantel and clean
Posted on Dec 28, 2013
I have a bes870 espresso machine hardly any steam came out the spout I checked clear the steam came out the filter and into the back of the machine. Please help
Have you cleaned the wand? Sticking the wand into milk eventually clogs it. Try the hot water option. If that doesn't work as well, clean the orifice with a toothpick.
May 04, 2016 | Breville Coffee Makers & Espresso Machines
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
No water coming out or milk coming out of spouts
This is a simple malfunction. Descale the machine one two or three cycles until the flow of water through the hot water pipe is with full jet.
The frothing will also be restored. If it does not, then you may need to clean the Milk stone clogging the frother. Milk stone is like cement and needs care and patience to clean without damaging the frother.
Good luck..
Oct 17, 2014 | DeLonghi Coffee Makers & Espresso Machines
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Milk does not come out of the milk spout
Do you have any errors is the spout clean try runing some hot water to open block channel see inside for seloniod
Jun 26, 2014 | DeLonghi Magnifica Coffee Makers &...
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Capresso Jura-Giga 5 Professional Home Coffee Machine - 13623 Logo
289 people viewed this question
Top Capresso Coffee Makers & Espresso Machines Experts
De Brewerz
De Brewerz
Level 1 Expert
Lawrence Oravetz
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
