Question about Dacor PCOR30 Convection/Microwave Oven
Panel not turning on - Dacor PCOR30 Convection/Microwave Oven
The vent will turn on randomly and not turn off!
Most over the range microwaves have a heat safety system built into them. If for instance you are cooking on the stove top for a long period of time on the burner directly under the micro control panel and the control panel get too hot, a thermostat in the microwave will automatically turn on the vent fan to help keep the control panel cooled off. My guess is that the safety thermostat (usually right behind the bottom of the control panel) may be going bad and needs replaced.
Apr 03, 2015 | Kenmore 30" Microwave Combination...
How do I fix my turn table in microwave sn676s
Most Microwave turntables are driven by a small motor under ther bottom. They usually have a small access panel on the bottom that covers the motor.Remove panel and you will see motor with 2 wires going to it. 1 or 2 screws hold stirrer motor in place.
Feb 28, 2015 | Panasonic NNSN657S Microwave Oven
Vent fan wont turn off
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
Apr 22, 2014 | Maytag Over-the-Range Microwave
Turntable does not turn
Possible that the belt has failed, or the motor is not working or that there is no power from the control panel to the motor.
You need to remove the bottom panel to observe this and confirm.
Feb 11, 2013 | Microwave Ovens
SHARP MODEL R895(SL)M TURNTABLE NOT TURNING
Check turn table motor operating voltage on the motor if the voltage is normal then check motor pulley(crack or broken) ,if o.k replace motor with the same type,if the voltage is missing go to the control panel and find out any wiring problem,if everything o.k replace control panel.
Jan 15, 2011 | Sharp R-303CW Convection / Microwave Oven
Fan and light keep running and panel is blank
mcdevito75 here, Sounds as though the control board could be faulty, check with any appliance repair center in your area.
Jul 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Control panel seems to be responsive, internal
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Sharp R-930AK Convection/Microwave Oven
New ge spacemaker microwave oven
It's probably a failed hood thermostat. That is usually located on the chassis floor behind the control panel.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor PCOR30 Convection/Microwave Oven Logo
20 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
