Question about Honeywell FocusPRO 6000 5-1-1 Day Programmable Thermostat - TH6220D1002
How to lock thermostat - Honeywell FocusPRO 6000 5-1-1 Day Programmable Thermostat - TH6220D1002
Where is the thermostat located on my 2000 madza b2500?
  1. Disconnect the heater return hose at thermostat cover. Disconnect ECT sensor and water temperature sender unit. Disconnect the upper radiator hose from the outlet connection. Remove the bolts. Pull elbow away from the cylinder head. Remove the thermostat and gasket.
The thermostat cover casting contains a locking recess into which the thermostat is turned and locked.
Do not use more than 15 - 20 ft ibs to tighten the thermostat housing bolts.
Mar 30, 2015 | 2000 Mazda B-Series
Need to put a thermostat in a 2000 madza b2500
Mar 30, 2015 | Mazda Cars & Trucks
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
Locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
I have a TB8220U1003 thermostat and I want to lock out the screen. the keypad lock out number is 0670. My options do not go that high on the stat..??
You have to click on the 'system' then hold the 3rd and 5th buttons on the bottom (about 5 seconds) then go down to 670, and setting 1. Repeat the process to remove lock, just change the setting to 0
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Can you lock in the tempture in the wall thermostat
I don't know....
To fix your problem you can put a lockable plastic cover over the thermostat.
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
I NEED TO LOCK TO CONTROLLER TO STOP PEOPLE CHANGING THE SETTINGS
Covers with locks are made for thermostats mounted in public places. Anyplace that sells thermostats should be able to obtain one for you. After you lock the cover over the thermostat make sure you put it in a place where it, the key can be found.
Jul 11, 2008 | Hitachi Heating & Cooling
If you lost the manua, you can go to their site and download it.
Hard to help more without a model number. Sorry.
Geno
Feb 22, 2008 | Honeywell Programmable Thermostat Heater
Honeywell FocusPRO 6000 5-1-1 Day Programmable Thermostat - TH6220D1002 Logo
98 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
