Question about Fedders C36ACD1VF Split System Air Conditioner
Problem with reset switch on fedders split unit
I have a problem with a split unt from fedders the light for replace filter is flashing and i cant get it to stop not even by pressing filter reset it will only come on if i hold the switch in and turn it on in auto mode can anyone help me
  • matyt94 May 11, 2010
    What is the model number?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
This indicates a fault within the unit. Call a service technician and have the system repaired.
I take the time to help you with your problem, so please rate me.
Thankyou Mat
Posted on Sep 10, 2009
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
My Mom has a Fedders Window Air Conditioner Model # A7T12F2A Serial # CP961286 075E
Switch off, press reset and switch back on. Keep reset pressed for 10 secs. Check the bit behind the filter is also clean and check the drain isn't clogged.
May 16, 2012 | Fedders Heating & Cooling
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Carrier Air conditioner. Turn the unit on and the Green unit light is flashing. But the system will not turn on. Have tried replacing battery in the contol, and the air filters have been cleaned.
make sure your getting power to unit is this a split or package if split make sure water is not in exterior drain pan this will kick the float switch out push contactor in see if it comes on if not check the capacitor please give me a rating and vote
Sep 19, 2010 | Carrier Heating & Cooling
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Fedders C36ACD1VF Split System Air Conditioner Logo
243 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
