Question about Hotpoint Dryers
Hotpoint aquarius vtd00 dryer clothes getting stuck all the time how do I fix
Clothes getting stuck between drum front edge and dryer wall. Have halved the loads etc but its getting worse please help
    New Friend:
  • 108 Answers
Hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
Posted on Feb 14, 2014
  • 1028 Answers
SOURCE: frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
Posted on May 06, 2008
SOURCE: help with door switch wiring.
Just found that my neighbour works for comet
Got full PDF. Whiring is as follows:-
3=Gray
4=Brown White
5=Pink White
Posted on Dec 31, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
  • 742 Answers
SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Posted on Oct 30, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "Straight-Forward answers, quick - ace!"
Hotpoint Aquarius VTD00 Model We have moved house and I have lost the Instruction Booklet and I want to fix a vent thro the wall. What is the recommended height relative to the machine please. GES
The lower the vent , the better ,then there is less chance of a blockage, and condensation forming in the hose or pipe.
It is also better if you can keep it relatively straight as well.
Trust this answers your question.
Cheers.
Jan 01, 2010 | Hotpoint Dryers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint vtd00 just replaced the belt for 3rd time put kids clothes into dry and loads of smoke and burning any clues?
Sounds like the motor is turning but the belt is not so, the belt is just setting there burning. You should be able to turn the drum by hand, check the drum rollers and the belt tension roller.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Tuble dryer not spining
sounds like your drum belt broke
Dec 01, 2007 | Hotpoint NWXR473EV Dryer
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
78 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
