Question about Midea MDC-45AE Dehumidifier
Model MDF1-30AE-BA5 instruction manual - Midea MDC-45AE Dehumidifier
Where can I find a instruction manual in French ?
Good Afternoon Ted, I am happy to assist you!
I see that your post is listed under Frigidaire dehumidifier and that you are seeking an instruction manual in French. May I have your model number please? You can typically locate the serial tag (which lists your model number) in the back by the water buck. With this information I can provide the correct manual to you and verify if it is available in French. Thank you and I looking forward to further assisting you. Best - Z
Sep 02, 2014 | Dehumidifiers
Zd30 year old does nothing !
check the fuse on the pcm board. 3 amp fuse. will need to open the unit up to get to it.
Oct 25, 2013 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
Dehumidifier manual
what is the model number to your dehumidfier Dennis
Oct 02, 2013 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
I need the intruction manual for Delonghi dehumidifier model #DE40P.
Here is a link to the Owner's Manual, you're looking for. You can download and print the manual for future reference. Take good care of your model, perform routine maintenance, as required. As it no longer in manufacture. It has been replaced with a 45 pint unit. However, some parts your model are still available, if needed.
http://www.appliancefactoryparts.com/content/pdfs/109280.pdf
Hope this helped you.
Jul 11, 2011 | DeLonghi DE40P Dehumidifier
Midea MDC-45AE Dehumidifier Logo
94 people viewed this question
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
 Russ Hill
Russ Hill
George Centrella
Level 1 Expert
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
