Question about Panasonic Televison & Video
Panasonic pt47wx52cf tv shut off and wont turn
Panasonic pt47wx52cf tv shut off ans wont turn back on have to unplug it then only comes on for a sec or 2 and off again red light flashing
  • lawncare1 May 19, 2009
    3 flashes between pauses
  • lawncare1 May 20, 2009
    well what does that mean and can it be fixed Convergence section
I have the same problem red light flash 3 times and pause for5 secs and flash again 3 times
Posted on Apr 06, 2010
Pt47wx52cf--can i set the convergence without a controller.my controller is broken
Posted on Jan 12, 2010
  • 10,594 Answers
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
Posted on May 18, 2009
  • Shahid Electronics
    Shahid Electronics May 19, 2009
    3 flashes shows Convergence section is defective, as per service manual.
    Shahid Electronics May 20, 2009
    Yes, it can be fixed.
    If you are handy with electronics stuff repair then can fix it by yourself by replacing two STK392-110 on main board, these are big ICs and mounted on silver heat sink.
    Above ICs are available in Part Store.
Lights went off now tv wont come back on
We recommend you remove all HDMI cables from the TV then unplug the unit's power cord for 30 seconds. Then plug the power cord directly into the wall. If the problem persists we recommend you have the TV evaluated by an authorized service center.
Mar 22, 2014 | Panasonic VIERA Televison & Video
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
47 projection
im sorry to say but you need to have a IC replaced on the main board to fix this
Sep 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv problems
Unplug the three red-blue-green plugs nest to the convergence amps. If the unit powers up and stays on the picture will look bad but will confirm that the convergence amps have failed...
Replacing the amps and one or more resistors in the yoke return will restore the set to normal operation..
Use only Sanyo original Ics..
Bill
Oct 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
548 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
