Question about Acer Computers & Internet
Acer iconic 200 wont turn on
Havent use it for amonth or ok and now it wont turn on
  • 47 Answers
It must b ur battery!! its nt been charged for a month...so its completely dead n may nt work , bttr go for the new one..!!!
Posted on Jan 04, 2014
Why my acer ferrary one 200 turn on, but no monitor/display, no hdd led flashing
If you are able to hear the fan running inside your laptop , then it should be possibily the mother board that needs to be checked.
Aug 11, 2014 | Acer Ferrari ONE 200-1799 Notebook
Acer Ferrari ONE 200 wont power up
you have to check that your battery is charging or not in your laptop by another laptop or battery,if problem is not solved,then check battery port
Dec 02, 2013 | Acer Ferrari ONE 200-1799 Notebook
I have done a hard reseet on my acer f900 now it shows arabic language!! can u help me to change it into english
TAP start- settings- system- regional settings( icon is earth)- locate English(ur country) in the search box- tap ok.
Next, TAP MULTILINGUAL SUPPORT( located near the regional settings, before the battery icon. Still the icon is earth but it has a somewhat ring figure)- locate your country. Then go to CONTROL tab located below<3rd tab>, unmark the first box then just below it, choose English with Arabic Enabled- tap ok.
Make sure to restart your handset. Long press the power button until it displays an icon that means do not turn off handset by removing the battery then if it's already off. wait for a couple of seconds, like 10seconds maybe then turn it on again.
Jul 08, 2011 | Acer F900 Quadband 3G HSDPA GPS Unlocked...
I havent been able to use the inbuilt mic of my acer aspire 4736z .i have not also been able to locate the mic in my computer and my operating systemis windows 7 ultimate 64 bit version and please help me...
May be your mic volume is turn off, Go to contol panel then look for the sound icon and open it check your mic volume if it was mute, then just uncheck the mute box to turn it on...
Jan 17, 2011 | Acer Aspire 4520-5582 Notebook
Acer aspire x1301 u9052 wont boot
Im not 100% sure about this but may i suggest you change the CMOS battery on the Motherboard, there is a chance that it is flat its a very common battery that you can purchase from your local store, but just change that and let me know what happens
Jun 19, 2010 | Acer Aspire X1301U9032 (PTSCM02007) PC...
The camera wont swich on and dont know how.
Here is a quick start manual.
http://pdf.crse.com/manuals/2590636111.pdf
It uses 2 R6 (AA) batteries.
You insert two batteries in the base, turn the dial on the top to the [camera] icon then switch on using the [power] button.
Hope this helps.
Mar 08, 2010 | Sony Cyber-Shot DSC-S80 Digital Camera
Kirby wont come back on checked outlet its ok
If you are refitting the shampoo tank, you havent turned it far enough. There is a safety switch that must lock
Mar 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My Acer T180 wont boot! =.(...
This sounds potentially like a failing memory stick. From another computer download and burn Memtest to a CD and try booting from it to test your RAM.
May 13, 2008 | Acer Aspire™ T180 PC Desktop
Creating Running Sum with Grouping Query
Looks like your GROUP BY subclause says to group by Force_no but also the yyyy and m datepart values for Subs_Dt as separate items. [Also since you are returning "Force_no AS FN", you need to refer to it as 'FN' and not 'Force_no' in the other subclauses of the statement. Same is true for your partial-date references as well in the SELECT subclause] So the query will return the grouping not by Force_no (should be FN) and some partial date but instead by Force_no (shoukd be FN), the year, and then the month.
The fix would be to group by a concatenation of the year and month and to change the references to the fields to be what you renamed them as in your SELECT subclause using "...AS...", for example:
SELECT GIS_Subs.Force_No AS FN, DatePart("yyyy",GIS_Subs!Subs_Dt) AS AYear, DatePart("m",GIS_Subs!Subs_Dt) AS AMonth, DSum("Subs_Amt","GIS_Subs","DatePart('m', [Subs_Dt])<=" & [AMonth] & " And DatePart('yyyy', [Subs_Dt])<=" & [AYear] & "") AS RunTot
FROM GIS_Subs
GROUP BY FN, AYear & "-" & AMonth
ORDER BY AYear, AMonth;
So now you have only 2 GROUP BY parameters instead of three and the grouped results won't be done by FN, then year, then month, but by FN and year-month. [As for the "-" in GROUP BY subclause, you can use any character you want as the separator; I just picked "-" since it is so typical.]
The DSum function in the SELECT subclause may also need some rework; also, possibly you will need to return [Subs_Dt] in the clause as well so DSum() has it to work with. Also check to be sure that reference to [Subs_Dt] is being recognized OK without using the "table!field" form of reference. I dunno if you need it given I don't know your whole table-field definition and so can't say if there would be a naming conflict someplace.
If you are still having trouble, try starting over and building this query piece by piece, one field, one condition, one subclause, at a time until you get to where it breaks for you. That'll be the "threshold of failure" you are looking for that should point you further in the right direction.
I hope this works for you. Let me know how it goes!
Feb 23, 2008 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
