Question about Measuring Tools & Sensors
Wavetek 9100 i need 10 ohm 22w and 10 ohm 21w
  • ahmed
    ahmed Dec 28, 2013
    Hi ahmed , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    i have aproblem in wavetek 9100
    i measured resistors R10 ohm 22 w and R10 21W it measured short cit
    would you mind helping me to buy thes resistors to fix my equpment
    Master:
  • 683 Answers
Interesting - you can troubleshoot Fluke calibrator but cannot source 2 resistors
First you label both resistors as R10 (is this a designator or actual value on the resistor - btw if this is a value written on resistor then R10 is 0.1 Ohm which would show as short and would explain high wattage also) and probably there is nothing wrong with them.
Need more info or pictures of what you thing are faulty resistors.
Also you can find Service manual here which would help in identifying components:
http://manx.classiccmp.org/details/59,15579
Posted on Jan 01, 2014
Wavetek dm27xt have a multimeter that when I try to measure some element, the digital display does not show the actual value of the measurement, only shows the initial value of the measurement range in...
Can you watch .mp4 or .avi files? The Youtube video is over 10mb in size, so it can not be sent (gmail has a 10mb size limit on attachments). I have to cut it into several smaller pieces and can convert to another file type (the original is an mp4).
Mar 03, 2014 | Wavetek Computers & Internet
Operator's manual/ owner's manual for wavetek fg2a needed
I couldn't find your exact model for free, but I did find the manual for the Wavetek FG2C. Perhaps they are similar? You can find it here: http://www.tequipment.net/assets/1/26/Documents/FG2C_FG3C_Manual.pdf
If not, you should be able to purchase the manual here: http://www.manualsdrive.com/results.php?lang=en&search=WAVETEK%20FG2A. I've never used that particular site, but the FG2A manual, installation guide, etc are listed.
Best of Luck!
Nov 07, 2013 | Wavetek Computers & Internet
WAVETEK 3000B SERVICE MANUAL
You can find the service manual in the bellow link. Contact to the email address listed there. Hope this will help you.
WAVETEK 3000B
Ajin
Apr 07, 2012 | Computers & Internet
Wavetek 320B Multimeter Calibration procedure needed. Specifically what do the 6 internal calibritation pots specifically adjust. The circuit board has these numbers: MD-HD110 & 33-5205F & 9917....
Wavetek 320B Multimeter Calibration procedure needed. Specifically what do the 6 internal calibritation pots specifically adjust. The circuit board has these numbers: MD-HD110 & 33-5205F & 9917. The calib. pots have these numbers: R06x, R031, R021, R23, R45.
vf2212@yahoo.com
Nov 25, 2009 | Meterman Wavetek VT101 Voltage Tester;...
Need a manual for a Wavetek DMM, digital multimeter model DM15XL
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Nov 15, 2009 | Measuring Tools & Sensors
Indicators not working,no wiring diagram
as you say your comp so here's the way i would go about it.pull say the left rear indicater wires from where they connect to the main frame loom. using the live feed connect a multi meter to this wire then set meter on ohms now with the other probe i would start at the turn signal relay, pull relay and put to one side. put probe into the connetor that relay came from probe on to the output . this should then create a connection to the left when you push the left indicater switch , now if you cannot make a circiut their move to the switch and you will then be able to work out if you have the right wire connected by checking which colors you have connected to the probes. now some where . if you did make a circuit 1st time then check to see if you have voltage at the relay connector when ignition on if you have votltage accross this terminal to earth on frame then you have a relay verses lamp watage prob , ie relay 21w+21w bulbs mixed ie 1 at 5 watt other at 21w , wont flash or addon led lights.
Nov 04, 2009 | 2001 Yamaha V Star 1100 Classic
WAVETEK SAM 3030 MANUAL NEEDED
go to:
www.clubdediagramas.com
they have a fee but they can get all the manuals you need.
Sep 17, 2009 | Televison & Video
I need to unlock my dsam wavetek cable meter i lost my user name and password
You need to connect to another cable guys dsam and bounce the settings from theirs to yours. You will need a crossover ethernet cable.
Aug 26, 2009 | Wavetek Computers & Internet
Resistors R30 and R31 on pcb 4233-1288d-b completely burnt.
R31 47 ohm 1/4 watt 5%
R30 100 ohm 1/4 watt 5%
Jan 26, 2009 | GPS
Measuring Tools & Sensors Logo
622 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
