Question about DeLonghi EC702
Espresso won't come out
First use of machine and water won't come out through filter. It comes out through frother but not through filter.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Replace
Posted on Dec 28, 2013
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Our seven-year old espresso machine is making a
Check the shower screen in the brew head.
Posted on Oct 10, 2009
  • 18 Answers
SOURCE: Espresso machine will not make Espresso.
Also, the outlets on the bottom of the portafilter may be plugged. Flip the portafilter over and look into the outlets. With the inner filter removed, you should be able to see light through the outlets. If not, these may be plugged from improper cleaning. Set the head of the portafilter in hot water for a few minutes to soften the plug, then using a soft wooden toothpick, clean out the jam. Once you get water flowing through, run a few empty shots to finish the cleaning and inspect.
Posted on Jun 11, 2009
While decalcifying the water comes out of the frother in intervals as it should but it does not come out of the spouts.
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
Sep 30, 2015 | Jura Capresso Impressa F7 Espresso Machine
I have a commercial wega double espresso and double frother. The frother works! you can see the fill line filled with water, but the espresso maker is not shooting water, you can hear it work when you...
This issue can happen if the site inlet water pressure falls below 1 bar. The boiler fills but as you draw drinks it won't refill.
Do you service the machine ever and replace the water filter? Limescale build up may be another reason you are experiencing problems.
Trouble shooting guide here
Espresso Maintenance
Sep 29, 2013 | Wega Coffee Makers & Espresso Machines
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Gaggia Classic First time use and no water comes out.
Me to! Not happy. Have you found any solutions to this? I don't really want to send away my machine that just arrived but also don't want to mess around with something that should work
Oct 31, 2009 | Gaggia Classic Espresso Machine
All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
Sep 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
No water or steam is coming out of the frother. Tried rinsing machine and going back and forth from brew to froth with no results.
Just fixed this same problem by taking apart the water solenoid valve and cleaning out its connection tube of deposits that was blocking water/steam flow. I removed the magnetic coil but that's not required. The connector was very tight because it had loctite sealer on the threads. I used plumbers teflon tape on the threads when reassembling.
May 11, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Dec 31, 2007 | KitchenAid PRO LINE KPES100PM Espresso...
DeLonghi EC702 Logo
348 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
