Question about Measuring Tools & Sensors
Wavetek 9100 i need resistor 10 ohm 22w and 10 ohm 21 w
    Master:
  • 683 Answers
Wavetek 9100 i need 10 ohm 22w and 10 ohm 21w
interesting - you can troubleshoot Fluke calibrator but cannot source 2 resistors
First you label both resistors as R10 (is this a designator or actual value on the resistor - btw if this is a value written on resistor then R10 is 0.1 Ohm which would show as short and would explain high wattage also) and probably there is nothing wrong with them.
Need more info or pictures of what you thing are faulty resistors.
Also you can find Service manual here which would help in identifying components:
http://manx.classiccmp.org/details/59,15579
Dec 28, 2013 | Measuring Tools & Sensors
What is the value in ohms, of a resistor in the X 1 scale of a Peak Ohmmeter
1 to 1. So 1 ohms on the scale is 1 ohms if it was X 10 1 ohms on the scale is = to 10 ohms
Dec 26, 2013 | sonata resistor - w/diode
Need Bissel 1715 wiring schematic. Charging circuit has burnt resistor. Need to know resistor details.
Can not believe NO ONE could answer this.
The R1 resistor basically drops the 9V to around 5V for charging the battery pack. The resistor is a 10 ohm , 2 watt resistor. The other resistor is 220 ohm. This only limits the current to the LED.
The 10 ohm resistor burnt because the battery pack was left to sit too long without use and charging. So the cells shorted causing excessive current through the resistor when you attempted to charge the batteries.
After replacing the resistor, you will need to replace the battery pack before charging. Otherwise, you'll just burn the resistor again.
Sep 27, 2010 | Bissell 1715-G Spotlifter Bagless Handheld...
Need a manual for a Wavetek DMM, digital multimeter model DM15XL
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Nov 15, 2009 | Measuring Tools & Sensors
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
Resistors R30 and R31 on pcb 4233-1288d-b completely burnt.
R31 47 ohm 1/4 watt 5%
R30 100 ohm 1/4 watt 5%
Jan 26, 2009 | GPS
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Measuring Tools & Sensors Logo
569 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
